Hello, how are you? I am having problems when starting the installation of macOS Big Sur from the USB, after starting the USB gives me error ACPI AE_NOT_FOUND SSDT also throws error SB.PCI0.LPC0
Could someone please help me to solve this problem? Thank you for your time.
My Notebook: HP Pavilion Gaming 15
CPU: Intel Core i5 10300H
RAM: 32GB
GPU1: Intel UHD Graphic Commet-Lake H-GT2
GPU2: NVIDIA GTX 1650
Disk1: NVME 256 GB SK Hynix BC511
Disk2: M.2 Samsung 870 EVO
BIOS Settings:
Safe Mode:
Off
SATA: AHCI
Virtualization: Off
Edited by Miguel Marquez
5 hours ago, Miguel Marquez said:
@MaLd0n how can i enter the configuration section of the olarila botteo? i don't see that option
red apple in the screen and go to installation
@MaLd0n Could you tell me how to access the configuration? How can I solve this error? Something specific. Maybe a little more than 3 words. Maybe it's silly for you but for new people it's not. I know I'm having problems with the gpu but I don't have access to a configuration.
Some Basic Information
-If you need edit config.plist use OpenCore Configurator last version and change Fork to MOD and Configuration Properties to last Development Version.
https://tinyurl.com/52tjt85m
-This OpenCore fork have good additional feature and we can boot into Windows with no problems with full ACPI solution.
-Remap USB
https://tinyurl.com/4r7paeen
-Remap USB
I thank you for your time I have seen those psobiles solutions that are post macos installation. My problem is that I can not get to install macOS, the error that I throw is at the time of the first boot to start the pre installation of macOS.
I burned the olarilla image on a pendrive 2.0.
but u replace efi folder for ur hardware?
the efi folder is replaced at the end of the installation and start macos right? i can not start the installation.
1: I downloaded macOS Olarila.raw and burned it in BalenaEtcher.
2: Download EFI folder for my hardware and burn it in another pendrive.
3: Configure the BIOS:
Safe Mode off.
Virtualization off.
SATA MODE. AHCI
3: Boot the flash drive on which you are recording macOS Olarila.raw. Click on the red apple and there I get the error that I show
Translated with www.DeepL.com/Translator (free version)
54 minutes ago, MaLd0n said:
apparently i was able to solve the problem i had with the EFI. now i have this problem when i start the installer.
note: in the configuration section, the config2 option for notebook devices does not appear.
config2 is a old thing. forget it
check ur procedure. something wrong there
obviously if something is wrong.
download image olarila.raw
save olarila.raw with BalenaEtcher
Assign EFI folder to another non-existing partition
Replace EFI Clover for intel 300 series notebook folder
Configure BIOS
Resetie NVRAM
Maybe config.plis needs some changes for my specific case? or should I boot the installation with the config.plis that comes with my hardware?
