Is B350M - Ryzen 5 1600x - RX580 suitable for Monterey? Any EFI for this system?
Hello all,
I want to install Hackintosh as a second OS and need some help please. Couple of years ago I installed High Sierra to hdd and now i have a 120gb ssd and give it a try to Monterey. If it works well i can change my ssd. Even I search somethings about my config, i couldn't find a proper way to install Monterey. Some says my system is ok for Monterey so if you think like that can you help me? I can't find a suitable EFI for my motherboard and cpu and not  know much thing about creating an EFI. As I remember only the wifi was not working on High Sierra and the other worked well but it was years ago and I guess my hardware a little out of date. Any help to follow the steps will be great thank you.
Cpu: Ryzen 5 1600x
MB: MSI B350M Bazooka
Ram: G-skils Aegis 2x8gb=16gb 3000mhz
Gpu: MSI RX 580 8GB
SSD: James Donkey 120 GB
Edited by Ahbab
