I have problem with sound (only the microphone does not work
I have a VIA VT2021 codec,but don't work my microfon.Can someone tell me solve this problem?
Thank you.
Mobo: GA-Z90 M Gaming CPU: i9 9900K RAM: 16GB Kingstone NVMe: Samsung 970 250GB SanDisk SSD: 500GB
On this link has only kext.No additional DSDT patch for AppleHDA.
Hello.
Do you have a new solution?
Yes. VoodooHDA is best choice to you.
I post my dsdt and my iOReg,iOdevice tree and Kextas.
You only need install VoodooHDA, isn't necessary patch DSDT, only AppleHDA need.
Try install VoodooHDA, but doesn't fix microphone problem, so post a dump your codec.
Excuse my bad english i am Brazilian user.
Only see my micrphon but don't work.Only work on windows.
I change my info plist as in the picture, when I asked.
Give me a solution?I'm still looking for answers on the network.
Thanks.....
Perhaps this will help you to help me.
Thanks!!!!!
269603249_ScreenShot2013-09-22at1_50_33PM.thumb.png.2c2c52e2281c5439e4874330db974779.png
963053524_ScreenShot2013-09-22at2_01_21PM.thumb.png.a6ca6b2a8e335450f230ec514cd2d868.png
Give me an example of how to do it.
Sorry......
I do not know how to do it.
Hello.
GPU - Grpahics Processor Unit, GPU is your graphic card.
Step by step
*Remove your GPU of your mobo(motherboard);
*Boot and Acess your OS X Installation;
*Get a dump your codec and post here;
You undestand now my friend?
Have you thought to start the system without GPU,to run across an integrated graphics.
So then we see that Dump Codec.
