System Info. A little confuse.
I downloaded the system info app. I ran the systeminfo.exe go to file and select the check comaptibility. After the only one result shows up. its about my nvidia GeFroce GT 630M with a green check mark.
On the tutorial page of systeminfo it says that green check mark means "device was reported as working". Does that mean the on my laptop thats the only device as working? or the ony device that is not working?
Explanation:
The reason i ask this is because artur told me and said that " nvidia don't work.. only intel hd 3000". But on system info its green mark. should'nt it be a sad smiley icon mark instead of green check mark?
Here is the image
man read all about optimus thec in mac os x ..
and i don't ask to u to check compability..
i ask to u to post u devices.. anyway u already post it in linux
so i just answer to u..
the nvidia don't work
only intel hd 3000
the wireless don't work
ethernet works
