Need DSDT Patch for GeForce GT 630 1GB GDDR5
Hello every one,I have a patch for my graphics card GT 630.
Shows me that I have a 512MB instead of 1024MB.
Thank you every one who know how to help me.
Mobo: GA-Z90 M Gaming CPU: i9 9900K RAM: 16GB Kingstone NVMe: Samsung 970 250GB SanDisk SSD: 500GB
probably is this u can try to apply
Device (GFX0)
                       Store (Package ()
                               "AAPL,slot-name",
                               "PCI x16",
                               "@0,compatible",
                               Buffer (0x0B)
                                   "NVDA,NVMac"
                               "@0,device_type",
                               Buffer (0x08)
                                   "display"
                               "@0,name",
                               Buffer (0x0F)
                                   "NVDA,Display-A"
                               "@1,compatible",
                               Buffer (0x0B)
                                   "NVDA,NVMac"
                               "@1,device_type",
                               Buffer (0x08)
                                   "display"
                               "@1,name",
                               Buffer (0x0F)
                                   "NVDA,Display-B"
                               "NVCAP",
                               Buffer (0x18)
                                   /* 0000 */    0x04, 0x00, 0x00, 0x00, 0x00, 0x00, 0x06, 0x00,
                                   /* 0008 */    0x09, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x0A,
                                   /* 0010 */    0x00, 0x00, 0x00, 0x00
                               "VRAM,totalsize",
                               Buffer (0x04)
                                   0x00, 0x00, 0x00, 0x40
                               "device_type",
                               Buffer (0x0C)
                                   "NVDA,Parent"
                               "model",
                               Buffer (0x16)
                                   "nVidia GeForce GT 630"
                           }, Local0)
                       Return (Local0)
If I can put this hack into a text document and to fix the patch as the DSDT editor?
Thank you....
I put the dsdt but we do not change the memory,what else can you be?
Good hack,but don't working for me.Do you have another suggestion?I have Gainward GeForce® GT 630 1024MB D5.
Thank you.
Do you have a my DSDT.aml.You search me everything do you need.
Thank you.
You are using GraphicsEnabler
GeForce GT 630 512MB NVc1 [10de:0f00]-[10b0:0f00] :: PciRoot(0x0)/Pci(0x1,0x0)/Pci(0x0,0x0) device number: 1
Method suggested by PimentelX86 should work.
Set this in your org.chameleon.Boot.plist
device-properties.txt.zip
Yessssssssss.This is it.Thank you very,very much.
Yes my GraphicsEnabler was to be a Yes,but now is No and working extra.
Sorry I'm late.I was not at home.
Thanks very much to help.Sorry I now change smbios on MacBook Pro 9,1
You have to create "send me" file after booting with GraphicsEnabler=yes
There's still no graphics card in your device-properties.
If it can be done HEX EDIT via OSX86 Tool.
Thanks.
