trackour Posted April 18, 2022 Posted April 18, 2022 Any help to get the external card working, on my zbook 15u g2 broadwellgpu hd5500DGPU firepro m4170In Monterrey > Hackintool shows: Opal XT [Radeon R7 M265/M365X/M465]deviceID:6604
Administrators MaLd0n Posted April 18, 2022 Administrators Posted April 18, 2022 i think dont work u need disable this card and use only igpu 1 -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
trackour Posted April 21, 2022 Author Posted April 21, 2022 Thank you for your reply, this site is very good, thank you for your support, the problem is I want to attach pictures so that you can see everything clearly.. image 1. image2 image3
Administrators MaLd0n Posted April 21, 2022 Administrators Posted April 21, 2022 use -wegnoegpu -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
Bas Hoogendoorn Posted September 7, 2023 Posted September 7, 2023 On 4/18/2022 at 11:31 PM, trackour said: Any help to get the external card working, on my zbook 15u g2 broadwellgpu hd5500DGPU firepro m4170In Monterrey > Hackintool shows: Opal XT [Radeon R7 M265/M365X/M465]deviceID:6604 device is not OPAL showed, its Topaz XT if it have no outputs. it works in OSX under 8600m Opal Pro/Mars that's the normal name if not mobile. here Dgpu is M265 and works full in Mojave witch switching only in Monterey must rewrite 2800 lines to wil detected or load by apple driver. M260 = Topaz M260X = Opal M265 = Opal the Mserie R7 26x M34x M36x M44x and 53x and 62x are all compatible as Opal Pro/mars all Pitcairn and troop cards
