Hi @MaLd0n I downloaded the latest EFI from the EFI Folders for Rocket Lake but i am gettting constant screen flashing on/off. See the video in the google link please. I went back to the old EFI but this remains the same with flashing. The screen works perfectly in Windows 11 but in Monterey and Big Sur it just flashes all the time. I tried to get the details using runme but i cant because of the constant turning off/on of the monitor.
https://drive.google.com/file/d/1PwassijOko-ptycQtuTfPWFplHnfZbPK/view?usp=sharing
Gigabyte Z490 Vision D
i7-11700K RocketLake
Powercolour RX6800XT
MacOS Big Sur
Monterey
what rx580 manufacturer?
I am using Powercolour RX6800XT since a year now
And the MB is Gigabyte Z490 VD
MacOS Big Sur
Monterey
csm is disabled?
is a very strange problem
go to monterey 12.3.1 and check if solve
It does the same in Monterey. I put in a display monitor calble to HDMI and it now works. Strange that HDMI is only affecting MacOS and not Windows so that rules out any issues with the graphics card. I did a clean install of Big Sur and Monterey and was still the same.
MacOS Big Sur
Monterey
