Good morning, i've a strange issue... any outgoing connection to a shared folder (even on a macbook air or QNAP NAS) using AFP and SMB protocol does't work...
I cannot also use an authentication meted...(user and pw) the strange is that if i shared a foldeer on my hackintosh from a can access with no prob from other pc... (so incoming works... outcoming not) . any suggestion????
Lion 10.8.4, q6600 - p5e3 deluxe GTX 550 ti 1 gb - 8 gb ddr3 corsair 1600
i can't understand nothing of u issue..
UPDATE:
Booting the system with an older chamaleon 2003 sharing SMB AND AFP work. Using the new chamaleon (to have iMessage working ) doesn't work. Any tip???
My issue is that I cannot connect any shared folder using SMB and Afp protocol with new chamaleon
Thanks for your help, but before I'd like to try a think...
I tested on my system too much chamaleon in order to have I message working , so I'll make a clean installation of ML again and I'll try directly chamaleon v2.2 r2156. Just to see if the problem persist. Just a thing ... What is it for i386 folder???
http://www.osx86.net/view/3856-chameleon-2.2svn-r2254.html
the i386 is to use with chameleon wizard
and selecting that folder.. the wizard use that files
