Hi Guys,
I just installed Big Sur 11.6.5 with clover on my Ivy bridge desktop with (Intel HD4000) , unfortunately the graphics works without acceleration...
Could you please support ?
I appreciate your prompt response
Kind regards,
if u use clover and system have support for ur ancient hardware just use InjectIntel
Hi Mate ,
Can you please support me ?
I try the following:
I try to install the HD4000 Patcher >OK
Restart > Hackintosh keep rebooting without success.
I reinstall the Monetery and try the OpenCore-Patcher-GUI Methode I still have the same issue .
I try with clover >KO >Acceleration failure ...
Could you please provide me Open core EFI for Ivy bridge desktop with (Intel HD4000)  I7 3370 , Motherboard: Arktek H61 /12gb Ram,
Let's keep this old PC alive and run the newest Hackintosh ?
I appreciate your support and your  prompt response,
Thank you very much and stay safe :)
i dont use unsupported hardware in new system. u need check it
Hi, I have a new update , I just installed the Patch as well , and the system still booting without a problem , unfortunately the graphics still have no acceleration although I can see under about this Mac that the graphics has 1536 MB.... :(
I already try with Opencore 0.7.9.
Any suggestions on how to enable the acceleration ?
Thanks in advance
Edited by Ali Mrad
what patch? non-vanilla patch?
use one system with full support for ur hardware like catalina
Thanks for your Answer:)
Yeah that'sa good idea, I will try this as soon as possible.
On 4/8/2022 at 11:44 PM, Ali Mrad said:
Hi Guys,
Kind regards,
Man, I once used a hackintosh on a Haswell Setup with an Intel HD 4000.
Used Catalina, but I didn't upgraded to Big Sur, due to compatibility issues.
According to GPU Buyers guide, you gonna have a better support
upgrading your processor to one that carries Intel HD Graphics 4200 ?
If you live in the USA, it will be nice to find one at a good price.
Edited by Matheus Sousa
