Installed Monterey 12.3 on Gigabyte B460 motherboard. All features working, except that the Realtek ALC 1200 audio is "muddled": very low volume & bass-heavy.
Used the "Olarila Monterey 12.3.raw" file burned to USB thumb drive, then replaced the EFI folder with the appropriate Crater Lake EFI folder, ran the installation procedure.
What would be the recommended procedure to fix the ALC 1200 audio? Thanks.
