u update the kernel patches?
1 hour ago, MaLd0n said:
actualizas los parches del kernel?
Hello MaLd0n, I have created the new efi for jonathan, the AMD patches.plist have been added, also nvmefix.kext
Also try Driver/NvmExpressDxe.efi
https://www.mediafire.com/file/jgqqcrn136aggev/NUEVA_EFI_V2.zip/file
the configuration is almost identical to mine, it only changes the ethernet card, GPU and in my configuration I do not use NvMe (m.2)
I use sata ssd and it works fine. the configuration (the one of jonathan) is used nvme m.2
It works for me without problems and everything vanilla, even now I'm on Monterey 12.3
create the new efi respecting the DSDT, and adding updated versions of KEXT already used
New Patches.plist AMD
but in nvme I don't know why it is not displayed as boot
Edited by sharklatan
use olarila efi folder for now with no dsdt with default config, just configure ur kernel patches
If I need help!
I have a current installation of catalina with OpenCore 0.6.x
AMD B450
Ryzen 2600
nvme 512gb
32GB of DDR4 RAM
DSDT patches
Everything has been working fine for a year.
Now i am trying to upgrade to bigsur and
I have created a new EFI with OpenCore 0.8.0, also and the updated kext, I have verified all the parameters (ocvalidate) and there is no problem
so far so good, the problem is that when booting from my updated EFI it doesn't show up to select the NvMe drive (even with catalina)
What can be?
What am I skipping and why is my drive not showing up?
2022-03-31 10.03.17 p.m..jpg.zip
