I installed Monterey on my system following the vanilla guide everything works great but sleep, I already mapped my ports and they seem to work fine but I still get the same error wen running command :pmset -g log | grep -e "Sleep.*due to" -e "Wake.*due to"
2022-03-15 16:13:41 -0400 Sleep               Entering Sleep state due to 'Idle Sleep':TCPKeepAlive=active Using AC (Charge:0%) 4 secs
2022-03-15 16:13:45 -0400 DarkWake            DarkWake from Normal Sleep [CDNP] : due to EHC1 EHC2/ Using AC (Charge:0%)
2022-03-15 16:31:26 -0400 Sleep               Entering Sleep state due to 'Idle Sleep':TCPKeepAlive=active Using AC (Charge:0%) 4 secs
2022-03-15 16:31:30 -0400 DarkWake            DarkWake from Normal Sleep [CDNP] : due to EHC1 EHC2/ Using AC (Charge:0%) 49 secs
2022-03-15 16:32:19 -0400 Sleep               Entering Sleep state due to 'Maintenance Sleep':TCPKeepAlive=active Using AC (Charge:0%) 4 secs
2022-03-15 16:32:23 -0400 DarkWake            DarkWake from Normal Sleep [CDNP] : due to EHC1 EHC2/ Using AC (Charge:0%) 49 secs
2022-03-15 16:33:12 -0400 Sleep               Entering Sleep state due to 'Maintenance Sleep':TCPKeepAlive=active Using AC (Charge:0%)
2022-03-15 17:09:02 -0400 Sleep               Entering Sleep state due to 'Software Sleep pid=152':TCPKeepAlive=active Using AC (Charge:0%) 8 secs
2022-03-15 17:09:10 -0400 DarkWake            DarkWake from Normal Sleep [CDNP] : due to EHC1 EHC2/ Using AC (Charge:0%) 14 secs
2022-03-15 17:09:24 -0400 Wake                DarkWake to FullWake from Normal Sleep [CDNVA] : due to UserActivity Assertion Using AC (Charge:0%)
2022-03-15 17:33:03 -0400 Sleep               Entering Sleep state due to 'Software Sleep pid=147':TCPKeepAlive=disabled Using AC (Charge:0%) 7 secs
2022-03-15 17:33:10 -0400 DarkWake            DarkWake from Normal Sleep [CDN] : due to EHC1 EHC2/ Using AC (Charge:0%) 12 secs
2022-03-15 17:33:22 -0400 Wake                DarkWake to FullWake from Normal Sleep [CDNVA] : due to UserActivity Assertion Using AC (Charge:0%)
2022-03-15 23:41:45 -0400 Sleep               Entering Sleep state due to 'Software Sleep pid=155':TCPKeepAlive=disabled Using AC (Charge:0%) 19 secs
kill all _prw
in some cases need synt tsc
