Monterey Installed but no SSDs, Wifi, LAN...since that EFI works well in Big Sur,
Hi Admin, Mod and friends,
I'm facing a big problem regards installing Monterey in my Hackintosh (Asus Zenith II TRx40, AMD ThreadRipper 3960X, AMD RX 5700XT, FenviT919 Wifi Card, 128GB RAM, 3 SSDs).
All the installation went throughly in Big Sur, even iMess, AirDrop, Handoff, Sidecard works like a charm.
I use exactly that EFI to install Monterey and:
- At the very beginning of the installation there's no wifi (at the corner where Language (Flag icon) should usually come with the Wifi icon)
- In diskUtility, it can see only 1 SSD (system mounted 3(s), can see in BIOS)
- After succeeded boosting in to Monterey desktop, there's no wifi, no LAN, and of course only 1 SSD.
I attached here my config.plist and also some pictures,
https://ibb.co/3sGrNZY
https://ibb.co/c3nPzMW
https://ibb.co/RNG6nBV
https://ibb.co/pxCcxYQ
I spent more than a week on seeking solution, and ...stuck for now?, is there something I missed or do we have to change the config.plist since Monterey is diff. from BigSur?
Is there any help would be much appreciated, thank you guys in advance, sorry for my bad English and I don't know is this post can be place here or somewhere more suitable in the forum.
Awaiting...for helps,
config.plist.zip
first, this config have a bunch of non-sense things
start with Olarila efi folder with correct kernel patch for ur processor and start a fine tune
Here we don't like generic things
Thank you very much for your attention,
Before posting this, what I've tried:
Use OC_GenX to generated EFU - Failed
Follow Dortania Guide to build EFI from scratch - Failed
This EFI I copied somewhere, get macOS Monterey installed, but nothing loaded (this EFI can install and boot BigSur, works)
I've tried https://tinyurl.com/3tpkbpmk, patch with my AMD 3960X (24 cores, number=18), failed.
Could you please have a look and tell me how to fix,
Thanks so much for your kindness,
