Why is it so complicated? I think I am using quite a common motherboard with common audio on it? Other people seem to have gotten it to work wit just the kext. What could be the issue? Different bios version?
Ps, I am using DVI-DVI by the way
I need to analyze your codec_dump
using a live version of Linux use this command in the terminal:
cd ~ / Desktop && mkdir CodecDump && c is in / proc / asound / card * / codec # *, the f = "$ {c / \ / * card / card}"; cat "$ c"> CodecDump / $ {f / / \ / / -}. txt, done && zip-r CodecDump.zip CodecDump
Everything works now :)
I have a fully working mackintosh I5 with 27 inch monitor and beautiful sound coming out of the speakers. I will use this system to make iphone games to my iphone and test.
Thank you very much for all the help, you guys have been really kind!
I wonder if there is something more I should do to the system or just let it be. I saw in some forums that I don't have any mkext so the cache systems seems to be broken.
I still need the sleep trick but at least everything is working now :)
Asrock z77 pro4 - I5 ivy bridge - Gigabyte Ati radeon 7870 OC edition - Acer 27" - OS: Mountain lion 10.8.4
@Pixeellegolas
no, you do not need a mkext.
As for sleep, I applied the patches needed for it
on some motherboards it works well in other not.
Do a test using the AppleACPIPlatform.kext 10.8.1 may resolve the problem of sleep.
Your HDMI audio works?
Actually the sound worked even without your latest files. I pulled out soundblaster, restarted computer into windows and made sound work there with internal. Now when I booted up mac osx sound worked...without me applying anything.
So I will try your new files soon. I was just happy now that everything works so afraid to break it :)
But if I can fix sleep that would be nice.
I will get back to you with results later
PS. have not tested HDMI sound yet. I dont use it on this comp anyway right now
SO, I tried with the new files you sent me and I also found a appleacpi kext here:
http://www.osx86.net/view/2649-appleacpiplatform.kext.html
And these guys combined, I still need sleeptrick but with the new appleacpi the black screen is much shorter time. Maybe from 1 minute to 10 seconds
