First I did the sudo kextcache
Then I repaired in disk utility, here I saw the it fixed the broken amdradeon kext
Then I used kext wizard to repair again and chose rebuild cache
In chameleon I have UseKernelCache=Yes and GraphicsEnabler=no
I still get the error about linked kext and still slow in os
Strange stuff
Asrock z77 pro4 - I5 ivy bridge - Gigabyte Ati radeon 7870 OC edition - Acer 27" - OS: Mountain lion 10.8.4
use only original kext from the system u have installed
now that thing is a mess...
with kext from one version.. others from other..
Hi! Yes, seems that I have some different kexts now and don't know witch one is witch? Would it be a good idea to get kext from someone on 10.8.4 so I can put them there again?
oops, saw in the zip now that you provided files for me :)
Hm, I have now recopied the kexts to s/l/e and repaired permissions and rebuilt cache. I also for the first time put these kexts in EXTRA folder.
Still I get kext error at boot. Now I get 7870 in system info at least but still no go. I don't know how to check QE but not transparent bar and no ripple effects in launchpad.
Shouldnt chameleon/chimera load the new kexts in EXTRA instead of the one in s/l/e?
Edit: I saw that I had no Extensions in EXTRA so created it and moved the kexts there. I also read the you should not use UseKernelCache=Yes because it will ignore the EXTRA folder.
Still get the same error....this is getting weird :)
Hi! I already did that before. Removed the kext files that was in the s/l/e and used Kext utility to copy over the provided to s/l/e. After I repair permission in both disk utility and in kext wizard. Still I got the same error for AMDRadeonaccelerator.kext. It is so strange
And the DSDT has been in root all the time and I can see that it is loaded in bdmesg
I know see alot of errors in disk utility when repair permissions:
Unable to set owner and group on "
Permissions differ on "......:" should be -rw-r--r--; they are rwxr-xr--x
Bar is not transparent and all homepages with a banner is really really slow
Edit: I might just download Olarila bootable usb installer instead and restart.
I started with niresh 10.8.2 and updated and I guess something strange happened. It failed every time but still changed to 10.8.4 so it works maybe 50%
I suggest you do a clean install
http://Olarila.com/forum/viewtopic.php?f=27&t=3101
Did a clean install with 10.8.4 and had some errors during install. After some kexts etc I now have a fully working mac. There are small issues right now with no sound and could not do a repair permission because of some strange error. Read about installing BSD from install etc.
There is just one last thing, I seem to have full acceleration with transparent bar etc. But still says 7XXX in info
install BSD.pkg
this folder within the package.
you are using the DSDT I sent you?
Hi! No, will try it soon. Right now I got kernel panic when trying to install voodoohda. I saw that I had applehda so there was a conflict. And also the voodoohds was old. Now I have updated voodoohda and deleted applehda. But I have no sound :)
Update: DSDT works! However, it first made 2 black screens at boot up so monitor got black 2 times. But then worked. Now it is just the sound that is the problem
Internal soundcard is on the ASROCK z77pro but I also have a soundblaster x-fi soundcard that I use
I tried using the guide to edit the VoodooHDA and insert my deviceID etc, totally according to the guide. but now I get KP after this. Before osx booted without any sound and it did not even look like it loaded the voodoohda. Now just KP.
I am thinking of maybe just using motherboard sound instead and skip soundblaster. I just use my desktop speaker anyway. Is it easier/more stable with onboards realtek?
Hi! Yes, I have now tried using kexts, used multi beast to install normal kext and also the ones that patch the dsdt.aml in extra but get no sound. In system info app it doesnt find the hardware and in system report it just says
: Intel HD sound Sound ID: 1
Try This: http://cl.ly/3d0W0o1N3U1p
How do I use the .txt file? I tried using the patch DSDT in chameleon wizard. I think it stated I was already running the DSDT. Do I need to boot without a DSDT, patch with the .txt and then run again?
Update:
Ran DSDT editor
Open DSDT file
Choose Patch
Pacthed with txt file
Choose compile, no errors
Save .aml
Installed it by dragging to EXTRA folder
Restart, nothing happens
7870 works fine but still no audio or a speaker or anything
Could it be a bios setting? It is set to auto on most stuff
Update2:
I am very very very stupid
I had AppleHDADisabler.kext in EXTRA and SLE that blocked the new one. I had it when I tried the voodoHDA kext. Now after removing and restarting I have the speaker icon and the system info looks good. But I still have no sound now. So need to check more why
Why is it so complicated? I think I am using quite a common motherboard with common audio on it? Other people seem to have gotten it to work wit just the kext. What could be the issue? Different bios version?
Ps, I am using DVI-DVI by the way
