PS. posted this on other forums too so I am "reaching out" :)
Hi guys! I have some issues these past days when it comes to my build. I can successfully start osx with 7870 but I have no acceleration. Here is a screenshot with info from system to tell you a bit more. Sometimes when I look at info it says 7870 and sometimes it says 7XXXX. I try to combine graphicsenabler with both yes and no, tried some different aticonfig like hamachi etc.
Uploaded with ImageShack.us
Do you guys have any pointers what to do next? I read somewhere about must having DSDT inject etc. I have never used DSDT before. The system works good except graphics.
I have theses specs:
ASROCK z77 pro
I5-3570k 3,4GHz
GIGABYTE 7870 OC 2Gb editition
Asrock z77 pro4 - I5 ivy bridge - Gigabyte Ati radeon 7870 OC edition - Acer 27" - OS: Mountain lion 10.8.4
what kext from ati are loaded in boot ?
see in terminal
kextstat
75    2 0xffffff7f80c8a000 0x66000    0x66000    com.apple.kext.AMDSupport (8.1.0) <73 10 9 7 5 4 3 1>
  76    0 0xffffff7f80cf0000 0x1da000   0x1da000   com.apple.kext.AMD7000Controller (8.1.0) <75 73 10 9 5 4 3 1>
  77    3 0xffffff7f80ab8000 0x8000     0x8000     com.apple.driver.IOPlatformPluginFamily (5.2.0d16) <9 7 6 5 4 3>
  78    1 0xffffff7f80eca000 0x12000    0x12000    com.apple.driver.IOPlatformPluginLegacy (1.0.0) <77 9 7 6 5 4 3>
  79    2 0xffffff7f80edc000 0xc000     0xc000     com.apple.driver.AppleSMC (3.1.3d11) <9 7 5 4 3>
  80    0 0xffffff7f80ee8000 0x10000    0x10000    com.apple.driver.ACPI_SMC_PlatformPlugin (1.0.0) <79 78 77 10 9 7 6 5 4 3>
  81    2 0xffffff7f80ef8000 0x12000    0x12000    com.apple.iokit.IONDRVSupport (2.3.4) <73 10 7 5 4 3>
  82    1 0xffffff7f80a7d000 0x3000     0x3000     com.apple.driver.AppleGraphicsControl (3.2.6) <81 73 10 9 7 5 4 3 1>
  83    0 0xffffff7f80f0a000 0xc000     0xc000     com.apple.driver.ApplePolicyControl (3.2.6) <82 81 73 10 9 7 5 4 3 1>
  84    0 0xffffff7f80b26000 0x3000     0x3000     com.apple.driver.AppleLPC (1.6.0) <77 10 5 4 3>
  85    0 0xffffff7f80b7e000 0x8000     0x8000     com.apple.iokit.IOUSBHIDDriver (5.0.0) <38 34 5 4 3 1>
  87    0 0xffffff7f80f1c000 0x5000     0x5000     com.apple.Dont_Steal_Mac_OS_X (7.0.0) <79 7 4 3 1>
  88    0 0xffffff7f80f21000 0x14000    0x14000    com.apple.kext.AMDFramebuffer (8.1.0) <75 73 10 9 7 5 4 3 1>
  90    0 0xffffff7f80f3e000 0x11000    0x11000    com.apple.iokit.IOSurface (86.0.2) <7 5 4 3 1>
  91    1 0xffffff7f80ac4000 0x3000     0x3000     com.apple.iokit.IOSMBusFamily (1.1) <5 4 3>
  92    1 0xffffff7f80f4f000 0xe000     0xe000     com.apple.driver.AppleSMBusController (1.0.10d0) <91 10 9 5 4 3>
  93    0 0xffffff7f80f5d000 0xc000     0xc000     com.apple.driver.AppleMCCSControl (1.0.33) <92 73 10 9 7 5 4 3 1>
  94    0 0xffffff7f80f69000 0x5000     0x5000     com.apple.driver.AppleUpstreamUserClient (3.5.10) <73 10 9 7 5 4 3 1
Tried Aji, Hamachi, duckweed and now Dashikawa. Mostly I dont see 7870 anymore but 7XXX instead. Will try a reboot with graphicsenabler=no once again
I am using 10.8.4 as you can see in picture. I have upgraded from 10.8.2 to 10.8.3 and then 10.8.4, but at both times I had some errors. Finally I copied the kext files to extensions :)
Will read alittle on that thread you posted now
Hi! That's the thing, I have never used DSDT so I need to make one. Will check some guides about it.
So here are the kexts. Could this be the bad boys making all the frustration? :)
PS. link to my files on previous page
Edit: So I saw that my Id was not present in ATIFramebuffer.kext so I found a new kext online and stuffed it in there instead. Also chose aticonfig=Chutoro that I think I saw somewhere is the correct one.
It booted into black osx and could not sleeptrick out of it. Had to restart and choose GraphicsEnabler=no to boot again
Ok, I see now that I dont even have AMDframebuffer. I have ATIframebuffer though. Could someone post the AMDframebuffer.kext?
Booting up with GraphicsEnabler=no and no aticonfig gives me same result as always. But now card is named 7xxx instead of 7870 again.
Could it be bios settings? Kext errors? I read somewhere about using hdmi or dvi port could do the difference. Stating ports etc. Trying all I can here :)
PS. By the way, I used the dsdt by choosing it in the chameleon wizard. I have it on desktop still. Do I need to use it in some other way? I see in chameleon wizard I can also Patch the dsdt etc
you have to put the dsdt the root system or the extra folder.
No change. Now I saw in bdmesg that it loaded the dsdt and I chose graphicsenabler=no
I do however notice an error that occurs just before the white screen:
kx(com.apple.AMDRadeonAccelerator)
Can't load kext com.apple.AMDRadeonAccelerator - link failed
Failed to load executable for kext com.apple.AMDRadeonAccelerator
kext com.apple.AMDRadeonAccelerator failed to load (8xdc000016)
stuff in parenthesis is fussy so dont know what it really says
further down:
ATY_init: Starting
ATY_init: Checkingg dev-id 6818
ATY_init: Card 0x6818 was posted
ATY_init: Quitting for card 0x6818
@pixellegolas
in a terminal type:
sudo ketcache -prelinked-kernel
then repair the permissions and rebuild caches using kextwizard.
