Dell Inspiron 13 7368 Laptop
Intel Core i7-6560U CPU @ 2.20GHz SkyLake
Intel HD 520 Graphics
Upgraded HD to 1TB SSD
Upgraded WIFI to Broadcom BCM94352Z DW1560
Installed OpenCore Monteray. Gets up to "Select Your Country or Region" screen. The trackpad is working as the screen loads. Then the trackpad freezes. The keyboard is also not working. My config.plist and log are attached.
Thank you in advance for all of your help.
Support.zip
Use this efi folder
https://easyupload.io/qxf216
Some Basic Information
-Remap USB
https://tinyurl.com/4r7paeen
I used your EFI. I looked at the USB video. The EFI you told me to use has XhciPortLimit disabled and includes USBInjectAll.kext and XHCL-unsupported.kext. I can not use hackintool till I get the mac booted and working.
I am able to boot and get the hello screen in various languages. I then get the language selection screen. I selected English. The trackpad and keyboard have been working fine. I then get to the Select your Country and Region screen. The trackpad and keyboard stop working right after this screen loads. This is using your EFI. It was working. What caused it to stop at this point? How can I fix it.
Thank you for your help.
Use mouse/keyboard usb for now. is mandatory for installation mobile(mouse) after u need start fix things
Thank you for your help. I plugged in a Logitech wireless mouse/keyboard into the USB. I only got to the language screen. The second I selected English it froze. I tried it several times. A few times it rebooted after about 20-30 seconds.
