I installed iAtkos ML2 on my acer aspire 5755G laptop, everything seems to be working fine except my laptop goes to sleep but wakes up immediately
i know what the problem, a device named EHC1 is causing it to wake up.
I have attached my DSDT hopefully someone can fix it.
Link for my DSDT:
https://www.dropbox.com/s/l3goozoc6k4zme4/dsdt
ACER ASPIRE 5755G
Intel® Core i7-2670QM CPU @ 2.20GHz Sandy Bridge
Intel® HD Graphics 3000/NVIDIA GEFORCE GT 540M
Mainboard- Acer JV51-HR
RAM - 8GB DDR3
Hi, thanks for your help my sleep works fine, finally :D
But i have another problem...
When my Hackintosh boots up the mouse and keyboard hang on the login screen for five minutes and then start to work and also if i logout they hang again and work after five minutes, i dont think its a kext problem since the trackpad/keyboard work fine after the 5min wait.
ACER ASPIRE 5755G
RAM - 8GB DDR3
that happen before ou after use that dsdt ?
it happened before aswell.
ACER ASPIRE 5755G
RAM - 8GB DDR3
i just used the dsdt.aml file he gave me...
ACER ASPIRE 5755G
RAM - 8GB DDR3
i think that is not related with dsdt
have u try the USBBusFix=Yes
must see in the boot what error messages... ???
is a mess u system...
u have a hp ?
if not why use kernelpatcher ?
other thing u are using extensions.mkext
in 10.8 it use kernelcache...
all kext in system/library/extensions
UseKernelCache=Yes
and in bios u must do something to usb...
usb legacy off ?
check here
http://Olarila.com/forum/viewtopic.php?f=28&t=1716
when i enable "use kernel cache" i get this error and i can only boot up in safe mode.
https://www.dropbox.com/s/zbxlweh5mspp6vh/20130628_204601.jpg
EDIT: sorry it isnt the kernel cache its chmeleon wizard, since i installed that i keep getting that error and have to boot up in safe mode.
ACER ASPIRE 5755G
RAM - 8GB DDR3
