need help for activate sleep and wake on acer 7741 (i3-380)
i am running ml10.8.3 on acer 7741 (i3-380)
whith intel first generation and all is ok
but i can't use sleep and wake
always reboot and blackscreen (chameleon) or open desktop but lag (clover)
i don't use ncpupm and there is no difference if i use ncpupm and sleepenabler
aicpupm is allready patched
i think that i need to patch my DSDT
but how whith this laptop (nothing found on the net)
i send the dsdt i use (allready patched for sound and backlight)
thank you for the help
dsdt.aml.zip
like u say this dsdt are already patched..
send a untouched dsdt...
try this one..
see the hdef device for u sound...
and take a advice.. not all hack wake well .. many mac some problem.. my config it sleep .. but never wake .. dark screen
@ arthur-pt
thanks for the work
with your dsdt, system sleep but black screen at reboot and i can't the system that is sharing
with chameleon and clover
can you send me the patch applied to dsdt
please
thanks
they are in forum
notebook core i
ehci for usb problems in sleep
after many hours , i always have problem with sleep and wake
wake is ok but when i want to use after wake desktop and mouse are ok but nothing else
mouse and keyboard have no effect , desktop is freeze
i can see the rep sharing with another mac but not the desktop sharing
i post dsdt that i use whith some modifications and an untouched dsdt
chameleon and clover give the same result
this is the last problem for me to run a perfect hackintosh
thank you
dsdt 7741.zip
