Hi, I have been banging my head against the wall on this one for a few days. I did successfully get catalina to install from the vanilla disc, but could not boot into it. the big sur disc allowed me to boot in but various things were not working. Any and all help would be great. I dont care what version of OSX I have to run as long as everything works :) Thank you for your valuable time.
I had to use the big sur vanilla olarila disc to get this dump. I think this is a desktop with some laptop parts. I am very curious to see what you discover. Also, this unit has only usb3 ports.
 Optiplex 7070MFF
Type: Micromini
CPU HexaCore Intel Core i5-9600, 4500 MHz (45 x 100)
Motherboard  Dell 0Y3R3K
Motherboard Chipset Intel Cannon Point Q370, Intel Coffee Lake-S
GPU Intel UHD Graphics 630 (1GB)
Disk Drive WDG WDS100T3G0C (1TB, 3200MBPS, NVMEG3)
Disk Drive WDC WD5000LPLX-75ZNTT0  (500 GB, 7200 RPM, SATA-III)
Network Adapter    Intel(R) Ethernet Connection (7) I219-LM
Wifi:  Intel(R) Wireless-AC 9560 160MHz
Memory SK hynix HMA82GS6CJR8N-VK 24GB
Realtek ALC255 @ Intel Cannon Point PCH - cAVS (Audio, Voice, Speech)
Send me Adams-Mac-mini.zip
Edited by BuffWellington
adding info
https://www.transfernow.net/dl/20220302SZLdsaaB
-Don`t open config.plist with OpenCore Configurator
I used your bigsur EFI and replaced the all in one dsdt with the one you made me and its working great! transferring over your manual changes now into the efi. Thank you so much, you rock!
Mapping the usb worked but will need to fine tune, causes slow boot.
