I just downloaded the olarila big sur vanilla image and made a usb bootable using balena etcher and after i boot using the usb stick and go to the bootloader which seems like clover i have no options in it to provide boot args or select config.plist  files it just has install macOS from usb, disable nv_ram and toggle sip options. Is this normal????  I need options to select config2.plistspacer.png
what ur mobo
Hi MaLd0n I am sorry I fixed it I didn't realize that i needed a real mac to transfer the EFI file of clover to the usb stick in my case my CPU is i5 10300h comet lake laptop chipset that has intel UHD graphics and a 1660ti dedicated (hp pavilion 15 dk10000) so I used the EFI of NOTEBOOKS CHIPSET SERIE 30 provided in the site  but now I  am stuck on attempting mach reboot. I have attached the snap of the error please check and help. Thank for your help so far please help me on this too.spacer.png
