[MAGICAL FIX ]Catalina Olarila Freezing on HP Z440 workstation
i think is about hardware accel
nvidia 710 dont generate it and ur processor don't have igpu for intel quick sync
I also have VGA QUADRO NVIDIA K2200 4 GB  GDDR5 but with Nvidia GT710 U see much better...Should I Try winth VGA Quadro  or get another VGA...!?!?
Very Thks $ Your Help MaLd0n have a good day ahead Everyone...!!!!!!
Hello MaLd0n on your last EFI had to delete AppleALC and put VoodoHDA To have Sound working...and THE CPU IS AL ALWAYS AT MAXIMUN 2300 MHZ as U can see on the istantanea...it is what U wanted or should I add some kext to let the cpu go a little lower...!?!?
Schermata 2022-03-25 alle 07.47.57.png.zip
Edited by startrek
amd cards generate it with only smbios iMacPro1,1 or MacPro7,1 nvidia no
Hello MaLd0n but for the cpu always to Max Speed with the Latest EFI U gave to me there is a way to have less cpu speed...It's always at MAXIMUM SPEED.....Many Thks Have a Good Day Everyone
Mald0n my hp z440 workstation with the new EFI U gave to me is always at maximum speed 2300 mhz as u can see from jpg seems STABLE but Im afraid this is going to burn my CPU on Mojave goes at much lower speed ...Can U made on Catalina my Cpu going at Normal speed Please....!?!?!?
Schermata 2022-03-25 alle 17.59.15.png.zip
Edited by startrek
Hello Mald0n !!! If U dont have another EFI to Try with Maximum Cpu Speed Always active at !00 % at the moment Im Back to Mojave...Please Let me know...!!! Have a Good Day Everyone...!!!! :)
is about kernel quirks for unsuport cpus
Hello MaLd0n but this always 100 % CPU Speed Is Going to Kill my CPU on the Long Run...!?!? Please Let me Know...!!!!!! under Mojave this problem do not exist....!!!!!????
1- there is some set on Bios to avoid this constant 100 % CPU usage...!?
2- Found CPUsetter.app maybe could help to solve the problem of 100 % CPU..!?
Edited by startrek
Hello Everyone Have a Good Day.....Reinstalled Catalina Olarila with the old EFI but formated in : (APFS uppercase / lowercase )...the install was Much Much FAster and all was setted automatically...MIRACLE...!!!!! Trying It Now.... letting U know after complete install of all programs....See U Later :)
SO FAR IT'S ALL GOOD No Freeze Well Well Well Lets Hope it keeps So Good.....!!!!!!
SSD formated in APFS uppercase/lowercase so important... didnt know :)
Edited by startrek
On 3/13/2022 at 11:59 PM, MaLd0n said:
dont change nothing
https://easyupload.io/nsl4ev
Dear MaLd0n Good morning......This EFI of  yours it's Very Near to let me install Big Sur on my Hp Z440 workstation but after all the verbose menu when should  be seen the white Apple it's ALL Black and nothing Happens....Maybe is my unsupported Gt710 on Big sur that cause this problem...!?!? There is some Code to Add in config.plist to let me complete installation...!?!? Please if there is a way to do so I would very much appreciate your help....!!!!!!!!
Have a Good Day ...!!!! :)
1 - Im going to add : NvidiaGraphicsFixup.kext on the kext of your EFI and try what it happens..waiting your reply if u like to do....!!!!!
2 -tryed to use the working kexts on OLD EFI Install Catalina working but is always no white Apple No block on Verbose dialog but when should show the white Apple is all black...!!!
In case was the vga what Video card should I use...!?!?
Edited by startrek
if ur video dont have support avoid it or use chriss patch
Dear MaLd0n U R the Best !!!  U R right from Mojave or Catalina I have  with Parallels : windows10 ( that I Hate Very much) Monterey and they work very well..... very Thks U gave me with your Hackintosh Olarila great satisfaction I run also many Linux !!!
Ask : have tryed Proxmox 7.12 installed Monterey but the passtrough is for me too much complicated....would U ever dedicate some section for this New Way to Run Hackintosh !?!?  i heard also of Unraid but do not understand well how it works !!!!!
OK Dear MaLd0n Very Thks  4 all U do....!!!!!  :)
Edited by startrek
bro
this problem seems like a hardware accel missing
43 minutes ago, MaLd0n said:
bro
1 - I dont chew much about hackintosh ,Google and Olarila MaLd0n are all my knowledge...Actually tring this :
sudo launchctl limit maxfiles 65536 200000
read on Macforum there are others Catalina users having problems of Freezing....!!!!
2 - installed Barrier.app on Osx Kvm under Linux helps to solve problems of audio....!!!! U never know it could help......!!!!   :)
3 -  I've tryed to Update All the kexts on the actual running good booting EFI like Lilu, Whatevergreen,VirtualSMC,XHCI-unsupported but seems to boot well but when there should appeard the white Apple it's ALL BLACK !?!? i thought Updating Kext would help to solve freezing but gives me this problem...!!! what a Mad World of Hackintosh...!!!!
4 - Remember the last EFI U gave me to Try !?!? I have tryed again but dont know WHY unable to Boot my Hackintosh setup of Bios is always the same !?!?  but sometime before it worked and have tryed to update to Big sur completed all the process and at the moment toenter in  Bigsur i was back in Catalina again saying dont remember what problem happened....!!!! Have U another EFI to try...!?!?
On MOjaveno one of these problems but i keep searching if i do find a Fix :)
Edited by startrek
dont change nothing
Hello MaLd0n !!! There is a mistery I have tryed your Above EFI and it let me update my Catalina to Big sur DOING ALL the process till last boot when it tells me there was a problem and was back again in Catalina....But Now what happens that when I put on the EFI it makes all the verbose menu but stay all screen black no apple white nothing happens... I havent chamged nothing in the Bios....have searched on Google but I have used it worked Good and Now doesnt work anymore !? Please have U any idea...!?
Edited by startrek
On 4/2/2022 at 1:59 PM, MaLd0n said:
WITH EFI MaLd0n Black screen all verbose working but No WhiteApple showing.
I took My Working Booting Freezing EFI Olarila and make many modifications:
<key>Boot</key>
    <dict>
        <key>Arguments</key>
        <string>npci=0x2000 dart=0 -no_compat_check alcid=1 -v -xcpm -cpufbeta watchdog=0 -hbfxoff UseKernelCache=Yes serverperfmode=1</string>
Then I opened my config.plist with cloverconfigurator and SETTED with the same values from the latest No Booting EFI of Maldon but leaving as iMac14.2 NOT MacPro1.1 otherwise wouldn't boot neither IF I SETTED as iMac14.4 NO BOOT...dont ask me Why I Do Not Know !!!!
Then added the  CPUfriend.kext and CPUFriendDATAProvider.kext from one-key-cpufriend.command and still Freezing.... Then DELETED VirtualSMC.kext and replaced with FakeSMC.kext and this Last but Not Least TRY Make THE MAGIC.....From this Latest TRYing My Catalina IT IS NO FREEZING ANYMORE....!!!!!
DEAR MALD0N I REMEMBER TO HAVE USED YOUR EFI(now no booting)and even tryed to update to Big Sur but no success but only after have done all the process of Installation....IF U ASK ME WHY I DONT KNOW I haven't changed Bios Settings IT'S A REAL MISTERY...Can U Find an Answer to this !?!?!?
HAVE EVERYONE A GOOD DAY AHEAD !!!!! :)
Edited by startrek
Have a Good Day Everyone !!! :)
In order to obtain more No Freezing protection possible I installed on /Library/Launchdaemons the file com.private.maxfiles.plist  which gives me automatically at every boot this : sudo launchctl limit maxfiles 65536 200000
Have updated all possible Kext one by one but I can't update Lilu kext to the latest version because this give me Black Screen at Boot....!!!!
Im also using Volta 1.2.5 .app that in mode performance make my intel xeon go from 2.3 mhz to 2.6 mhz not always but when Max Speed of intel xeon reach 2.6 mhz on windows10 reached 3.1 mhz.....!!!!
Most Of The Freezings That Still Happens Is When I Use FIREFOX with Safari do not Freeze....!!!!
Please MaLd0n have some suggestion.... I tried to update to the latest version of Clover but IM sorry unable to boot always Black Screen....Ok always searching with Google but every mackintosh hardware is another story.....much much trouble and every update is even more trouble....Apple Poisoned don't want u do mackintosh work Good.... :)
com.private.maxfiles.plist.zip
Edited by startrek
no answer canceled
Please MaLd0n give me an answer to This :
I cloned my Mojave Olarila to another SSD then copied your modified EFI on EFI SSD and this time Booted as happened not far away....the CPU is showing always at 2300 mhz and now Im upgrading to Catalina with this EFI.....Im asking the CPU showing always at maximum speed 2300 mhz of my Intel xeon E5-2670 V3 it's dangerous for Life Health of the CPU...Can I Use the PC in this way without problems.....Please Let me know---!!!!!
Dont Know why using the same EFI on the SSD of Catalina do not boot and stay all Black Screen...!!!!!!----> I cleaned on this SSD all Kexts and copied the ones on the fresh installation of Catalina and updated the EFI partition with the latest EFI MaLd0n and Catalina Boots Good.....these Hackintosh are really a mistery.....Very Thks 4 All but waiting if this always On max speed 2300 mhz could give problems is Intel Power gadget that give me this data.. !!!!
Edited by startrek
