[MAGICAL FIX ]Catalina Olarila Freezing on HP Z440 workstation
Hello Olarila Team !!!
Running Mojave Olarila updated to the latest version No Problems All running Good...!!!
I Was on Catalina latest version but lately many Freezing happening  and have to force reboot...have updated all Kext to the latest versions but No Luck
On Mojave it's all perfect running Catalina, Monterey,windows10 on Parallels.
Please if U have some Fix to solve this Catalina Bug Let me know....Super This and have and Have Everyone a Good Day Ahead !!!!
I am on : HP Z440 workstation
intel xeon processor E%-2670 V3
32 GB DDR4  SSD 500 VGA Nvidia Gt710
Forgot to write but dont see the modify on the first post...Must be something on the latest updates because it's a long time  using Catalina without these freezings...hachintosh is problematic
However Mojave Olarila Works Really Smooth without Freezing ...Very Thks... If U have some FIX for catalima Please Let me know !!!!!Thks !!!
Note : the Efi integrated on the latest olarila catalina raw doesnt let me boot on my Hp Z440 workstation have to chanfe the Efi to the one that worked and let me install Catalina and is running now on Mojave and U find on zip attached !!!
Schermata 2022-02-25 alle 20.41.30.zip
Edited by startrek
what chipset? x79 or x99?
should be x99 so far I know !!!!!....
HP Z440 workstation
intel xeon processor E5-2670 V3
Edited by startrek
Tryed : EFI.Opencore.Desktop.HEDT.Haswell-E  mounted on EFI but on my HP Z440 workstation Catalina doesn't boot....However seems to have found a workaround running Good--->Opened config.plist and from cpufriendfriend found : 0x0D for HWPEnable as U can see from the imagine attached and downloaded all night long 3 files with downloader updated microsoft office 2019 and there was No Freezing...!!! on Catalina macOS 10.15.7 (19H1819) Beta...!!! However  unable to update to Bigger and Monterey with this actual Efi...!!!!
Shoud I enter the data I have on my actual working EFI to yours EFI.Opencore.Desktop.HEDT.Haswell-E...to enable update to Bigger or Monterey on HP Z440 workstation..!?!?
Super Thks 4 your Help if U have some Fix 4 Update macOS Please Let me know and Have a Good Day Ahead Everyone !!!!
 U need report of run me to create an EFI for HP Z440 workstation to install Bigsur !?!?
Please let me know !!!!
Schermata 2022-02-26 alle 05.30.39.zip
Edited by startrek
the best is change this nvidia. go to amd rx560+ with iMacPro1,1 smbios
Good Morning MaLdOn this file aml is for the EFI of Catalina Haswel that U sent to me or the  Old one I am running Now with 0x0D patch on HWPvalue....!?!?
So I should change the actual : SSDT-OLARILA.aml with Yours : DSDT.aml .....Or Add tis on folder Patched !?!? Please tell me how should I Do the right Way Thks !!!!!
Schermata DOMINGO alle 07.25.48.png.zip
Edited by startrek
remove ssdt, add dsdt
u need check about freeze
the best is used amd gpu with iMacPro1,1 smbios
Changed as U said and seems much smoother and reactive so Far No Freezing...Keep Trying so...I'll let U know...!!!!
the best is used amd gpu with iMacPro1,1 smbios ...!?!? <-----Do not understand this does it mean i should change Gt710 with gpu amd !?!?!?
Have a Good Day Everyone !!!!!
Edited by startrek
On 2/27/2022 at 3:38 PM, startrek said:
    <key>CPU</key>
    <dict>
        <key>HWPEnable</key>
        <true/>
        <key>HWPValue</key>
        <string>0x0B</string>
        key>QPI</key>
        <integer>100</integer>
        <key>Type</key>
        <string>0x0A01</string>
        <key>UseARTFrequency</key>
        <false/>
<key>Arguments</key>
        <string>npci=0x3000 dart=0 -no_compat_check alcid=1 -v -xcpm<</string>
added -xcpm to boot arguments !!!
Tryed the DSDT U send to me but no luck...the only way to have a Catalina quite stable so far is to set on config.plist the value HWPValue to 0x0D...... Ok If u happen to have something else to Try Please Let me know....Many This $ Help and Have a Good Day Everyone  :) :) :)
Added Volta 1.2.5 from here : https://dfiles.eu/files/txskd9e51
this app enable turboboost on hackintosh not on all cpu but on my Intel Xeon e5-2670 v3 it does enabled turboboost and performance ...So far my Catalina is finally STABLE !!!!! :) :) :) :) :)
Updated to the latest Beta macOS 10.15.7 (19H1823)
............IMPORTANT : with Hackintool Updated All the Kext to the latest Version and instaled in Library\Extensions and then Runned Kext Utility ...!!!!
4 Me The Problem Is Solved If U Don't Have Another Efi 4 my HP Z440 Workstationn
to try...have a Good Day Everyone !!!!!
Edited by startrek
updated info
Hello Everyone !!!
This morning Updated to the latest version of Catalina Beta and after updating have Black monitor at Boot....returning to Mojave and update to Catalina but the default Version....!!!!
Apple The Most Advanced "PAY FOR EVERYTHING OS IN THE UNIVERSE :)   "
Back to Catalina but Normal Version No Beta....Installed macos Server 5.9 and seems to ADD some Code that Helps To Give Stability to My Catalina on HP Z440 Workstation....If someone have problems of Stability Freezing TRY to install macos Server 5.9 Maybe Inject some Code that helps to have a system more stable...!!!!! :)
With Hackintool updated Lilu CpuTscSync NVMeFix kext hoping this would Help to give More Stability to this Facking Catalina of Apple...!!!!!
Keeps Freezing so after all little Tryes went back tu Beta but this time after update No Black Monitor...!!!! If continues Freezing back to Mojave Stable...I am Sorry 4 this No One Finds a Fix 4 all this freezing with Catalina on HP Z440 workstation ...!?!?!?
Have a good Day Everyone...!!!!! :)
Edited by startrek
Finally The Real Fix Working Good on my hardware...!!!!
With Hackintool Updated all the kext on my EFI installed on my SSD with the exception of : AirportBrcmFixup intelMausiEthernet because if updated this ones there was after NO INTERNET...!!!! updating LILU and all the rest as U can see on the picture down...!!!!
seems to Have Really Solved All My Problems Of FREEZING CATALINA....I am on Beta macOS 10.15.7 (19H1824)
Very Happy with Catalina NO FREEZE.....!!!!!!!!
Have a Good Day Everyone...!!!!! :)
Schermata 2022-03-11 alle 07.44.52.png.zip
Edited by startrek
I am so Sorry but with this Fucking Catalina there is No Way to Have It Stable....Back to Mojave....!!!! :)
If Mald0n have some suggestion or whoever else  is Very Appreciated....!!!!!
Edited by startrek
dont change nothing
https://easyupload.io/nsl4ev
On 3/13/2022 at 11:59 PM, MaLd0n said:
dont change nothing
Ok Super Thks  !!!!!! ill ......... WOW this new EFI U gave to me seems to Let me Update to Big sur and even to Monterey.... Now I am on IMacPro 2017..going to clone to another SSD and try to update to Big sur... for Stability have to use a little to see if Fix this issue....All Good so Far.....Super Thks I'll Let U Know..... :)
Tryed to Update from SSD with Mojave to Bigsur....It Did All the process of installing but at The End of Installation No Big Sur still On Mojave for some problem with the disk...!?!?
Tried to  Update from SSD with Catalina It starts but after few minutes Stop Install..!!!
However on Catalina after about 4 hours of low speed download with Jdownloader2 there was no Freezing ...keep trying but Your latest EFI is Very Very powerfull....( Only have to delete AppleALC.kext because on my sistem have to use VoodoHDA.kext dont know why maybe it's a usb speaker and have some problems with AppleALC... dont know....Dear MaLd0n U R The Best I am going to make a Donation to Olarila.......Very Very Happy Have a Good Day Everyone !!!!
On Linux Zorin I am running Catalina with Sosuni and is Very Very Speedy....Big Sur with OSX KVM but No Soubd and very speedy... of course also windows 10 but don use never....Linux is Fantastic...!!!! Have a Good Day Everyone....!!!
Edited by startrek
Tomorrow going back to MOjave ...this Catalina Dont Want to Stay Stable.....If Mald0n have something else To Try Please Let me KNow !!! IM so Sorry but Mojave is very very fast...faster than Catalina !!!!!!
