I have this motherboard and I need to patch my DSDT to make sleep/power management working properly. :oops:
I have searched the internet for a patch but have found nothing except a 'generic' P8 patch here: http://Olarila.com/forum/packs.php
Is there someone who could help find one/make or, or give me information on making my own?
Great thanks,
Patrik.
Great thanks,
Patrik.
Send me your untouched DSDT.
thanks,
what do i do with it?
Do i put it in my /extras folder in my boot USB or on my installed mac drive, or do i need to patch it with a patcher?
thanks,
patrik
man.. if u don't know how to use it.. don't use..
dsdt is not mandatory to run mac os x ...
have u read thle links i post ?
Alright I applied it but whenever i boot i get
WARNING: IOPlatformPluginUtil : getCPUIDInfo : this is an unknown CPU model 0x3a
-- power management may be incomplete or unsupported
And I cannot boot without using -x, which is useless as I need to be able to use my graphics card fully for FCPX! :(
what smbios are u using ?
and read about u graphics
the hack is yours...
u want i config u system ?
Sorry man but you're not really making much sense to me :?
I havent selected one. What is one that I should select?
I am going to try MacBook Pro Retina 10,1
http://Olarila.com/forum/viewforum.php?f=28
no sense ... u are using a notebook smbios in a desktop...
read and read all about...
or simply by a mac and u problems gonne..
mac os x is for mac, developed exclusively for mac
u know any mac with u config ?
hack mac os x is 99% of reading, googling, persistency and 1% of luck u hardware be compatible..
Listen, I came here for help with getting my motherboard and CPU working. I've run Mac OS X on a PC numerous times. I own plenty of macs and I know how they work.
So I came here for help and I am not getting any.
Also sorry your english is a little off so I'm having troubles understanding, that's what I meant :P
I seem to be having problems with SMC too, with alot of 'Failed for key REV' errors. I'm just asking for help and I think I should take this to another forum.
Thanks,
Patrik.
