Hey guys. I have been trying to get Mac OS X on my PC for past few days. I downloaded iatkos and nerish builds and tried to install it but it stuck on PCI configuration and on iatikos I get kernel panic. Now I am downloading the build available on this site 10.8.4 and tomorrow I am goin to try that. Would it work on my particular configuration? I will try to install it tomorrow and if I need any help then I will come back here.
I am getting pci configuration error. It gets stuck at that on chamleon bootloader and on chimera i get the error that this mac is not supported. What should i do?
try in boot
npci=0x2000 or 3000
Tried both but it didn't work still get stuck at pci configuration and some times at console 1024 768 resolution line. I also added the modified iopcifamily ktext but that didn't help either.
