I've made my own DSDT and I got almost everything working smoothly
Shutdown, sleep, audio, etc.
but I cannnot get speedstep working I only get 2 steps.
I've tried ssdt, generate P and c states and both without any luck.
I'd really appreciate your advice.
Thanks.
Intel DH57DD
ATI HD 5600
i3 550
Send me .zip
with that cpu
only need p and c-states=yes and remove the nullcpupowermanagement.kext
later on i take a look in u dsdt...
no ssdt...
with that cpu
no ssdt...
Hello Artur
Did you find sth weird in the DSDT?
with that cpu
no ssdt...
Double check this time NullPM isn't loaded and still only 2 states (minimum and maximum)
Send me .zip
with that cpu
no ssdt...
Changed ACPI_SMC_PlatformPlugin from macbook pro 8,1 and it works perfectly.
