Kernel panic with h67-itx-c-e with autopatch DSDT
Hi,
i use DSDT autopatcher to patch my H67-ITX-C-E dsdt but unfortunately,
i have a kernel panic (intelcpupowermanagement.kext) using the original dsdt patched with dsdt auto patcher
i checked , in HPET, method STA return to 0X0F and the CRS Method return to CRS as mentionned as the HPET fix
for that i can remove the nullcpupowermanagement.kext in the extra\extension folder ( that work fine if i have the nulcpupowermanement.kext)
anyone could help me?
thanks
Hi
Just try it, but unfortunately doesn't work still the kernel panic :cry:
HPET enable in bios setup?
post a photo
Hi,
the HPET is not present as an option in my bios, maybe it couldn't be change and alway enable.
there is screenshot of my bios and the KP message
Hi,
so using multishit to apply smbios:
imac 12,1: same kernel panic screen
imac 12,2: freeze at: FakeSMC: 17 preconfigur......FREEEEEEEEEEEEEZZZZZE and every reboot, it 's freeze at this same line.
argh :cry: the h55 itx-c-e wasn't so hard to be fully working :roll:
Hi,
try with USBBusFix=Yes
Hi problem solved,
it was the speedstep script that i use incorrectly,
i copy ApplleIntelCPUPowwerManagement.kext on the desktop and remove the one in the S/L/E folder
then i applyied the script on the desktop folder AppleIntelCPUPowerManagement.kext and when patched, i drop it in the kextutility,
reboot and then : VOILA!
