jamesst20 Posted February 23, 2022 Author Posted February 23, 2022 23 hours ago, MaLd0n said: u just need add _prw into device xhci Sad news, I've got one freeze What would be the next step? TSC_sync_margin=0 ?
Administrators MaLd0n Posted February 23, 2022 Administrators Posted February 23, 2022 u need test it bro -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
jamesst20 Posted February 24, 2022 Author Posted February 24, 2022 On 2/23/2022 at 7:27 AM, MaLd0n said: u need test it bro Still testing, so far no freeze. About the USB Wake Support, you said I needed to add to your DSDT Method (_PRW, ....) in XHC Opening my original DSDT in MaciASL (dumped with SSDTTime in Windows), I can see that Method (_PRW, ...) is present several times and in the custom DSDT you made me it's totally gone. I'm trying to understand: does it mean every device listing the _PRW method has the capabilities to wake my computer which could lead to unwanted/random wake? If so, is that why you removed it everywhere in the first place? Also, the custom DSDT you made me is much leaner that my original, how did you clean it up? Are you using some kind of tool or script or it's done by hand? Thanks again MaLd0n!
Administrators MaLd0n Posted February 24, 2022 Administrators Posted February 24, 2022 9 minutes ago, jamesst20 said: I can see that Method (_PRW, ...) is present several times and in the custom DSDT you made me it's totally gone u need add only _prw from XHC device 9 minutes ago, jamesst20 said: I'm trying to understand: does it mean every device listing the _PRW method has the capabilities to wake my computer which could lead to unwanted/random wake? If so, is that why you removed it everywhere in the first place? _PRW: Power Resources for Wake and _DSW: Device Sleep Wake 10 minutes ago, jamesst20 said: Also, the custom DSDT you made me is much leaner that my original, how did you clean it up? Are you using some kind of tool or script or it's done by hand? i have all chipsets in my brain ? The way start here with us with dsdt editor and patcher and dsdt auto-patcher since 2006 Maciasl with my preferences, compiler, etc https://olarila.com/files/Utils/MaciASL.app.zip 1 -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
jamesst20 Posted February 26, 2022 Author Posted February 26, 2022 On 2/24/2022 at 8:36 AM, MaLd0n said: u need add only _prw from XHC device _PRW: Power Resources for Wake and _DSW: Device Sleep Wake i have all chipsets in my brain ? The way start here with us with dsdt editor and patcher and dsdt auto-patcher since 2006 Maciasl with my preferences, compiler, etc https://olarila.com/files/Utils/MaciASL.app.zip Thanks for the detailed response It's very appreciated and indeed impressive. I would like to report that my sleep issue appears to be resolved. Not a single sleep issue since I added TSC_sync_margin=0. According to the ACPI documentation, _DSW is optional just like you said. I'm a developer but far from familiar with the ACPI syntax/language. Still wondering though, since you have so many people like me requesting optimized DSDT, did you make yourself some script or it's manual work by hand every time ? I will edit the DSDT you made me later and add _PRW in XHC and report back
Administrators MaLd0n Posted February 26, 2022 Administrators Posted February 26, 2022 2 hours ago, jamesst20 said: I will edit the DSDT you made me later and add _PRW in XHC and report back check here. very nice work from these guys https://www.olarila.com/topic/24542-opencore_no_acpi-opencore-with-additional-featureschanges-implemented/ -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
jamesst20 Posted March 2, 2022 Author Posted March 2, 2022 (edited) On 2/26/2022 at 4:48 PM, MaLd0n said: check here. very nice work from these guys https://www.olarila.com/topic/24542-opencore_no_acpi-opencore-with-additional-featureschanges-implemented/ That's very nice ! Thanks I had never heard of this fork before. I'm wondering why the "EnableForAll" doesn't exist in the official build. It makes too much sense to not be present. Windows/Linux don't require any acpi patch. No doubt some people are having troubles. Edit: Question For learning purposes: Let's say my original DSDT has the following How would I write a patch that makes sure it can't wake the computer? I gave a try for fun and wrote this DefinitionBlock ("", "SSDT", 2, "hack", "_XDCI", 0x00000000) { External (_SB_.PCI0.XDCI, DeviceObj) External (GPRW, MethodObj) // 2 Arguments Scope (_SB.PCI0.XDCI) { Method (_PRW, 0, NotSerialized) // _PRW: Power Resources for Wake { Return (GPRW (0x6D, Zero)) } } } It sadly doesn't appear to have done anything ? What did I do wrong? Edited March 2, 2022 by jamesst20
Administrators MaLd0n Posted March 2, 2022 Administrators Posted March 2, 2022 Xhci device -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
jamesst20 Posted March 2, 2022 Author Posted March 2, 2022 (edited) 7 hours ago, MaLd0n said: Xhci device Sorry for the confusion, I am not trying to add those methods to XCI to bring back wake capability by USB. I'm trying to learn how SSDT patches work and are made. Let's make a scenario where one device is waking up the laptop and I would like to remove wake capability. In that example I would like to remove _PRW and _DSW seen there: I wrote this SSDT patch and added it to OpenCore folder: DefinitionBlock ("", "SSDT", 2, "hack", "_XDCI", 0x00000000) { External (_SB_.PCI0.XDCI, DeviceObj) External (GPRW, MethodObj) // 2 Arguments Scope (_SB.PCI0.XDCI) { Method (_PRW, 0, NotSerialized) // _PRW: Power Resources for Wake { Return (GPRW (0x6D, Zero)) } } } This patch don't appear to replace/overwrite the method shown in the screenshot. It actually seems to have no effect. Would you mind explaining me what is wrong with my patch? Edited March 2, 2022 by jamesst20
Administrators MaLd0n Posted March 2, 2022 Administrators Posted March 2, 2022 device to wake from usb is xhci not xdci -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
jamesst20 Posted March 3, 2022 Author Posted March 3, 2022 23 hours ago, MaLd0n said: device to wake from usb is xhci not xdci Don't worry I know, the question is not about that
Administrators MaLd0n Posted March 3, 2022 Administrators Posted March 3, 2022 2 hours ago, jamesst20 said: Don't worry I know, the question is not about that im use _prw for example only into xhci and lan device(wake from lan) only it -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
jamesst20 Posted March 3, 2022 Author Posted March 3, 2022 (edited) 6 hours ago, MaLd0n said: im use _prw for example only into xhci and lan device(wake from lan) only it The question is : How to write a patch that remove/delete/disable _PRW from device XDCI without rewriting complete DSDT.aml Tried this and doesn't work: DefinitionBlock ("", "SSDT", 2, "hack", "_XDCI", 0x00000000) { External (_SB_.PCI0.XDCI, DeviceObj) External (GPRW, MethodObj) // 2 Arguments Scope (_SB.PCI0.XDCI) { Method (_PRW, 0, NotSerialized) // _PRW: Power Resources for Wake { Return (GPRW (0x6D, Zero)) } } } Edit: Now this is about your DSDT.aml you made me. I edited it and added in XHC Method (_PRW, 0, NotSerialized) // _PRW: Power Resources for Wake { Return (GPRW (0x6D, 0x03)) } and I noticed 3 things: 1. Built in PS/2 touchpad is not working 2. Instant wake if my USB mouse is connected 3. Built in USB Keyboard doesn't wake the computer. Edited March 3, 2022 by jamesst20
Administrators MaLd0n Posted March 3, 2022 Administrators Posted March 3, 2022 u need rename _PRW to XPRW for example and inject new -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
jamesst20 Posted March 6, 2022 Author Posted March 6, 2022 On 3/3/2022 at 6:17 PM, MaLd0n said: u need rename _PRW to XPRW for example and inject new How can I inject new?
Administrators MaLd0n Posted March 6, 2022 Administrators Posted March 6, 2022 inject ur acpitable , dsdt or ssdt -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
jamesst20 Posted March 7, 2022 Author Posted March 7, 2022 9 hours ago, MaLd0n said: inject ur acpitable , dsdt or ssdt Won't it break USB Wake ?
Administrators MaLd0n Posted March 7, 2022 Administrators Posted March 7, 2022 u need test after edits -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
