HP G6-1b35ca
Intel core I3 370M
2.4ghz
graphics intel hd 3000
Mountain Lion 10.8.3
Everything works fine except graphics.
i have been trying for sometime to try to get some kind of graphic acceleration on.Please can someone help me out in editing something in dsdt to enable some kind of graphics.
attached is a copy of what my dsdt look like extracted.
Device (GFX0)
Name (_ADR, 0x00020000)
Method (PCPC, 0, NotSerialized)
Method (PAPR, 0, NotSerialized)
Return (Zero)
Method (_DOS, 1, NotSerialized)
Store (And (Arg0, 0x07), DSEN)
If (LEqual (And (Arg0, 0x03), Zero))
If (CondRefOf (HDOS))
HDOS ()
Method (_DOD, 0, NotSerialized)
If (CondRefOf (IDAB))
If your CPU is Intel Core i3 370M (1st gen) your video is Arrandale and not HD 3000. Arrandale does not have support in OS X, the max you can get is this
http://Olarila.com/forum/viewtopic.php?f=28&t=2961
Thanks i was able to get native resolution using the guide you provided.Although the only screen that has any acceleration is the laptop monitor.VGA port not working.
Any possible way to enable a VGA ?Add it in the kext ?
maybe edit the kext AppleIntelHDGraphicsFB.kext?
