blackscreen, can't see bootloader as well. tried with and without shikigva=128, blackscreen
Edited by gaule
did clean install but same problem. Can you please patch the dsdt for me one more time. If not working again then I will leave it, lost too much time on it. thanks
not working, it works without DSDT. Time to move to M1 as time and efforts does not worth anymore with hackintosh. Love to do hackintosh as side project though. Thank you again for your support.
Use without for now
Olarila efi have a basic
As I have little free time today, I analyzed the DSDT and seems to find the solution. Just removed this block of code, complied and bluetooth seems to be working.
Device (BLTH)   // ? removed entire block
                Name (_HID, EisaId ("BCM2E7C"))  // _HID: Hardware ID
                Name (_CID, "apple-uart-blth")  // _CID: Compatible ID
                Name (_UID, One)  // _UID: Unique ID
                Name (_ADR, Zero)  // _ADR: Address
                Method (_INI, 0, NotSerialized)  // _INI: Initialize
                    Store (AMW1, ^^LPCB.HPET._CRS)
                    Store (AMW2, ^^LPCB.RTC._CRS)
                    Store (AMW3, ^^LPCB.TIMR._CRS)
                    Store (AMW4, ^^LPCB.IPIC._CRS)
                Method (_DSM, 4, NotSerialized)  // _DSM: Device-Specific Method...
Hope someone with the same problem may help. Thank you for your support MaLd0nhave a good day ?
Edited by gaule
Good!
Enjoy!
  • Thanks 1
