Ok, I was able to install macos catalina and fix the wifi problem. The next problem (I think it's a problem) is that catalina macos are very slow. My mouse is slow and has some bugs in safari.
My PC:
Processor: Intel Core i7 3630QM
Memory: 8GB DDR3
OS: macOS Catalina 10.15.7
GPU: Intel HD Graphics 4000
video is activated?
check hackintool
System Info
Host                           MacBook-Air-de-Jhonata.local
OS                             macOS Catalina Version 10.15.7 (Build 19H4)
Kernel                         Darwin 19.6.0 x86_64
RAM                            8.00 GB
Model Identifier               MacBookAir5,2
CPU                            Intel(R) Core(TM) i7-3630QM CPU @ 2.40GHz
Intel Generation               Ivy Bridge
Platform ID                    0xFFFFFFFF
Board ID                       Mac-2E6FAB96566FE58C
FW Version                     422.0.0.0.0
Serial Number                  C02HA041DRVC
Hardware UUID                  ED664DCF-75C7-5F11-B2FE-0E75E3C952B5
System ID                      9152B080-5329-1299-A197-21DA46310C1A
ROM                            50B7C30357BB
Board Serial Number            C02140302D5DMT31M
VDA Decoder                    Decoder Failed
Serial Info
Country                        China (Quanta Computer)
Year                           2012
Line                           137 (copy 1)
Model                          MacBook Air (13-inch, Mid 2012)
Valid                          Unlikely
IGPU
GPU Name                       Intel 3rd Gen Core processor Graphics Controller
GPU Device ID                  0x01668086
Total VRAM                     0 MB
Free VRAM                      0 MB
Quartz Extreme (QE/CI)         Yes
Metal Supported                No
Metal Device Name              (null)
Metal Default Device           No
Metal Low Power                No
Metal Headless                 No
