Hi, my computer restarts when I click shutdown.
I originally used the coffee lake efi folder from https://www.olarila.com/topic/5676-folders-for-all-chipsets-clover-and-opencore/ and the shutdown works perfect.
I made changes to fix usb3, wifi, bluetooth, icloud etc. Everything is working fine but the shutdown restarts.  I'm not sure what I'm doing wrong. I'm new at this. Thanks for your help.
I also tried the files from this thread but they did not work for me:
https://www.olarila.com/topic/9467-shutdown-fix-dsdt-patch/
what ur hardware
bios/uefi in default
just disable csm if need
Getting closer :)
Turning off CSM in BIOS helped to shutdown the OS but my CPU fan and LEDs stay turned on. Any ideas?
Edit: The Sleep option works perfect
Edited by risk_two
bios/uefi in default?
hello good night, I'm new here and I'm having a shutdown problem on my old PC a ga-x48-ds5 running 10.13.6, everything works relatively well except shutdown and sleep if you can help me thank you!
Edited by Dj Marcelo Cerato
20 hours ago, Dj Marcelo Cerato said:
ga-x48-ds5
old gigabytes mobo need a shutdown patch with PM Base
