Hello, I have a problem with the battery monitor, I'm using AppleSmartBatteryManager.kext but I only have this on the menu bar:
and I can see this messages on my system.log:
Apr 26 00:01:26 MacBook-Pro kernel[0]: AppleSmartBatteryManager:getBatteryBIF(0xE00002BC) failed
Apr 26 00:01:26 MacBook-Pro kernel[0]: AppleSmartBatteryManager:getBatteryBST(0xE00002BC) failed
How can I solve this problem? Someone told me that I would have to modify my DSDT to solve it, but I don't know how, so, any help would be very appreciated.
Thanks in advance.
Dell XPS L702X: Intel® Core™ i7-2670QM + 16GB DDR3 + 17.3" FullHD WLED AG + NVIDIA GeForce GT 550M + Seagate Momentus 750 GB 7.2k HDD + Integrated 10/100/1000 Network Card + Atheros AR9280/AR5BHB92
the easy way is to use another appleacpiplatform , from snow...
like this one
http://www.osx86.net/downloads.php?do=file&id=1384
the hard way is from dsdt
read and try to apply...
http://www.insanelymac.com/forum/topic/264597-hp-dvx-acpi-3x4x-battery-driver-106107/
Thanks for your answer artur. I'll try the hard way. ;)
Finally, I have managed to make it work:
:mrgreen::mrgreen:
