DEAR ALL
I can't fix DSDT. Please help me fix it.
Thanks for help.
Main: Arock 890 GX http://www.asrock.com/mb/AMD/890GX%20Pro3/
CPU: AMD,AthLon,II,x4,635,(2.93GHz)
Ram: 6G
VGA: Onboard
OS x 10.8.2 (Niresh) http://niresh12495.blogspot.com/2013/03/nireshs-os-x-1082.html
This Link download My DSDT. https://www.box.com/s/bcshpj7qi18tmz1kkusb
Error https://www.box.com/s/dpbb88wh4jkqmyvbkt2q
This is Error information
Intel ACPI Component Architecture
ASL Optimizing Compiler version 20110112-32 [Jan 13 2011]
Copyright © 2000 - 2011 Intel Corporation
/Applications/DSDTSE.app/Contents/Resources/DSDTFiles/dsdt.dsl 2325: And (ECAD, 0xFFFE, ECIN)
Error 4096-syntax error, unexpected PARSEOP_AND ^
/Applications/DSDTSE.app/Contents/Resources/DSDTFiles/dsdt.dsl 2326: OperationRegion (ECBP, SystemIO, ECIN, 0x02)
Error 4064 - Object does not exist ^ (ECIN)
/Applications/DSDTSE.app/Contents/Resources/DSDTFiles/dsdt.dsl 2331: OperationRegion (ECIO, SystemIO, ECIN, 0x02)
/Applications/DSDTSE.app/Contents/Resources/DSDTFiles/dsdt.dsl 2363: Acquire (ECMU, 0x5000)
Error 4064 - Object does not exist ^ (ECMU)
Warning 1105-Result is not used, possible operator timeout will be missed ^
/Applications/DSDTSE.app/Contents/Resources/DSDTFiles/dsdt.dsl 2375: Release (ECMU)
/Applications/DSDTSE.app/Contents/Resources/DSDTFiles/dsdt.dsl 2380: Acquire (ECMU, 0x1388)
/Applications/DSDTSE.app/Contents/Resources/DSDTFiles/dsdt.dsl 2394: Release (ECMU)
Warning 1100 - Statement is unreachable ^
/Applications/DSDTSE.app/Contents/Resources/DSDTFiles/dsdt.dsl 2398: Acquire (ECMU, 0x1388)
/Applications/DSDTSE.app/Contents/Resources/DSDTFiles/dsdt.dsl 2412: Release (ECMU)
/Applications/DSDTSE.app/Contents/Resources/DSDTFiles/dsdt.dsl 2567: If (ECEN)
Error 4064 - Object does not exist ^ (ECEN)
/Applications/DSDTSE.app/Contents/Resources/DSDTFiles/dsdt.dsl 2574: If (ECEN)
/Applications/DSDTSE.app/Contents/Resources/DSDTFiles/dsdt.dsl 5108: Acquire (MUTE, 0x03E8)
/Applications/DSDTSE.app/Contents/Resources/DSDTFiles/dsdt.dsl 5120: Acquire (MUTE, 0x03E8)
/Applications/DSDTSE.app/Contents/Resources/DSDTFiles/dsdt.dsl 5133: Acquire (MUTE, 0x03E8)
/Applications/DSDTSE.app/Contents/Resources/DSDTFiles/dsdt.dsl 5146: Acquire (MUTE, 0x0FFF)
/Applications/DSDTSE.app/Contents/Resources/DSDTFiles/dsdt.dsl 5158: Acquire (MUTE, 0x03E8)
/Applications/DSDTSE.app/Contents/Resources/DSDTFiles/dsdt.dsl 5171: Acquire (MUTE, 0x03E8)
/Applications/DSDTSE.app/Contents/Resources/DSDTFiles/dsdt.dsl 5184: Acquire (MUTE, 0x03E8)
/Applications/DSDTSE.app/Contents/Resources/DSDTFiles/dsdt.dsl 5375: And (CTRL, 0x1E, , CTRL)
Error 4096-syntax error, unexpected ',', expecting ')' ^
/Applications/DSDTSE.app/Contents/Resources/DSDTFiles/dsdt.dsl 7079: Method (CCMN, 3, NotSerialized)
Warning 1088-Not all control paths return a value ^ (CCMN)
/Applications/DSDTSE.app/Contents/Resources/DSDTFiles/dsdt.dsl 7249: Method (SETV, 2, NotSerialized)
Warning 1088-Not all control paths return a value ^ (SETV)
/Applications/DSDTSE.app/Contents/Resources/DSDTFiles/dsdt.dsl 7990: Add (Local1, 0x80)
Warning 1105-Result is not used, operator has no effect ^
/Applications/DSDTSE.app/Contents/Resources/DSDTFiles/dsdt.dsl 8463: Method (WMAA, 3, NotSerialized)
Warning 1088-Not all control paths return a value ^ (WMAA)
ASL Input: - 8639 lines, 306538 bytes, 3064 keywords
Compilation complete. 12 Errors, 15 Warnings, 0 Remarks, 66 Optimizations
man what u are saying no sense...
the dsdt.dsl u post no errors...
there it is..
DSDT.zip
and minimum u ask help here use our tools like DSDTEditor
Thank you very much.
there it is..
[attachment=0]DSDT.zip[/attachment]
Hi Friend.
When i use DSDT.aml --> Bios reset when i restart OS. How to Fix this.
there it is..
