Hello, im Manuel and i need your help.
I have this pc:
I5 3330
ga b75m d3h
2 x 4GB 1333 value ram kingston
hd 7870 ghz oc sapphire
wd 500 GB blue caviar AHCI compatible
I tried almost everything i think, -X, -X GraphicsEnabler=no (i know i have hd 2500 but i should be able to install and boot, and later when boot finish the 7870 should work well right? I think the bios is well configured (vt-d disabled, ahci mode, and two other things that I dont remember how they were called). When it boot´s white apple appears a few seconds later kernel panic.
Sorry for my bad english, thanks
How did you build the installer? What boot loader are you using?
Yes, I did that. What error do you get with Clover?
No one, just when trying to boot to install
Sorry, I don't understand.
Ok, but the kernel panic is exactly the same as with Chameleon?
The picture you posted is using Chameleon, right?
Sorry for the spam, didnt see page 2 u.u and tought the messages werent send, and i never had used chameleon, may I try it?
Yes, try Chameleon, press 1 at boot.
GraphicsEnabler is a Chameleon option, it won't have any effect in Clover.
It will work with your build? And thanks, your job is awesome
Im sorry to keep asking, you must think that im a jerk, but i cant get a usb bootable chameleon or chimera for windows
Chameleon is included in the image, you just have to press 1 at boot (when you see the blinking cursor at top left).
thanks, it worked but got another kenerl panic after using chameleon (tried without any flag, with graphicsenabler=no,-x graphics enabler=no and -x
