@MaLd0n Hello. i am sorry to bother you again but my trackpad suddenly stopped working. while checking the ioreg it seems the i2c devices aren't getting fully recognized. Idk why. Maybe you can take a look please:) Thank you so much and sorry for bother. some infos that may help you I guess: apic id - TPD0, trackpad - syna2b52 which is i2c and smbus at the same time. thats how i remember from windows thoough. Thank you
sendme file:
https://we.tl/t-Z8MWWwU9l1
mess kexts and kexts order
Hi Mald0n. I kinda remade my EFI and added the DSDT you patched. Well, I dont know why but it's not working whatever I do. I did change the kext order in different ways, like google says and a lot more. What else can I do more?
https://we.tl/t-73x5KZpZbC
the best is start with olarila efi folder for ur hardware
is a clean efi folder, no renames, etc
panic(cpu 0 caller 0xffffff7fb345e27f): assertmsg@/Library/Caches/com.apple.xbs/Sources/GPUDriversIntel/GPUDriversIntel-16.5.7/IONDRV/CFL/AppleIntelFramebuffer/AppleIntelController.cpp:29499
Backtrace (CPU 0), Frame : Return Address
0xffffffa070f1b9c0 : 0xffffff801988c26d
0xffffffa070f1ba10 : 0xffffff80199d3993
0xffffffa070f1ba50 : 0xffffff80199c3f8a
0xffffffa070f1baa0 : 0xffffff8019830a2f
0xffffffa070f1bac0 : 0xffffff801988ba8d
0xffffffa070f1bbe0 : 0xffffff801988bd83
0xffffffa070f1bc50 : 0xffffff801a09c7ba
0xffffffa070f1bcc0 : 0xffffff7fb345e27f
0xffffffa070f1bcd0 : 0xffffff7fb340212b
0xffffffa070f1bd40 : 0xffffff7fb33fe672
0xffffffa070f1bdd0 : 0xffffff8019fc484b
0xffffffa070f1be40 : 0xffffff8019fc43de
0xffffffa070f1bef0 : 0xffffff8019fc357f
0xffffffa070f1bf50 : 0xffffff8019fc62f6
0xffffffa070f1bfa0 : 0xffffff801983013e
      Kernel Extensions in backtrace:
         com.apple.driver.AppleIntelCFLGraphicsFramebuffer(16.0.5)[C79561A8-A37E-3F3C-B320-A43D9AFEE39E]@0xffffff7fb33cd000->0xffffff7fb348dfff
            dependency: com.apple.AppleGraphicsDeviceControl(6.3.5)[2943A57C-11EA-349E-ABF5-0AC7DED914EA]@0xffffff7fb2f50000->0xffffff7fb2f53fff
            dependency: com.apple.iokit.IOACPIFamily(1.4)[5B13B648-2033-3C43-9806-CC47FED932BC]@0xffffff801be44000->0xffffff801be45fff
            dependency: com.apple.iokit.IOAcceleratorFamily2(442.9)[F7B6BAA2-1B1C-3905-9242-208418037EC3]@0xffffff7fb45ba000->0xffffff7fb4624fff
            dependency: com.apple.iokit.IOGraphicsFamily(585.2)[18F5DD47-7688-37AB-A74A-5AF8B45A4E0F]@0xffffff7fb473c000->0xffffff7fb476afff
            dependency: com.apple.iokit.IOPCIFamily(2.9)[C14212B3-F922-3073-B54C-9DE243057AF4]@0xffffff801c36b000->0xffffff801c393fff
            dependency: com.apple.iokit.IOReportFamily(47)[37461963-03B3-38F8-89AE-C2E4CF31422B]@0xffffff801c3a2000->0xffffff801c3a4fff
Process name corresponding to current thread: kernel_task
Boot args: -v alcid=3 watchdog=0 igfxonln=1 agdpmod=vit9696 -vi2c-force-polling -igfxblr -noDC9 igfxfw=2 igfxagdc=0
Mac OS version:
20G314
Kernel version:
Darwin Kernel Version 20.6.0: Wed Nov 10 22:23:07 PST 2021; root:xnu-7195.141.14~1/RELEASE_X86_64
Kernel UUID: C67468D8-72C1-36BC-A0DA-CD5FA852AD32
KernelCache slide: 0x0000000019600000
KernelCache base:  0xffffff8019800000
Kernel slide:      0x0000000019610000
Kernel text base:  0xffffff8019810000
__HIB  text base: 0xffffff8019700000
System model name: MacBookPro16,4 (Mac-A61BADE1FDAD7B05)
System shutdown begun: NO
Panic diags file available: YES (0x0)
Hibernation exit count: 0
System uptime in nanoseconds: 13837212979
Last Sleep:           absolute           base_tsc          base_nano
  Uptime  : 0x000000033ab17927
  Sleep   : 0x0000000000000000 0x0000000000000000 0x0000000000000000
  Wake    : 0x0000000000000000 0x00000006382a023a 0x0000000000000000
umm booting with the olarila efi for my notebook (coffee lake plus). I dont know what's wrong, Also, in verbose mode it was mentioned something about ionvmecontroller i think.
the problem is video. use ur old video patch in this folder
Okay. I did some researches on my own but no luck. I tried your efi, trying to adapt it with your patched dsdt but no luck. I guess there's something in the DSDT which makes the i2c controllers to not be recognized also in ioreg and settings. the thing is, using my previous efi with ssdt and ssdt xosi + patch for it, it WORKS but badly if I don't use the command that forces polling mode! but breaks during sleep. while booting with your dsdt + no other ssdt + no patch for xosi, it doesn't work. Tho, it is not being recognized in the ioreg, neither in the settings. I am posting my previous EFI + my new EFI (the one which contains your patched dsdt) + ioreg when booting with my previous efi + ioreg when booting with my new efi. Maybe can I get some help, sir?
first of all, i'll be sending the dsdt you patched: https://we.tl/t-ttpOIbdoTV
i decided to send you the runme when using the old efi: https://we.tl/t-Cg2sp9gRnL
and about when using the old efi, it just makes the i2c controllers (there are 2), being recogznied as pci... something like that, and no, it doesn't work. I ll appreciate your help through this. Thank you
smbios is MacBookPro16,1 and video patch bellow
Quote
            <dict>
                <data>CQClPg==</data>
                <key>framebuffer-fbmem</key>
                <data>AACQAA==</data>
                <data>AQAAAA==</data>
                <data>AAAwAQ==</data>
            </dict>
synaptics devices die after sleep if using voodooi2c
um yeah i knoow. should i try voodoormi instead? it is i2c and smbus trackpad from what i've seen from windows. Maybe using the smbus kext will make it work better than the i2c? the thing is isn't being recognized neither after sleep. Just if I using the ssdts i mentioned, it is working normally, but breaks during sleep which is normal. Should be there something I can do by myself? I have no idea at the moment,
Edited by David Tirddea
i never try voodoormi but many people report sucess
u need test
