Need lion kext and dsdt patched for Acer Aspire AM7720
Yes, that's the one I'm using
http://code.google.com/p/voodoohda/downloads/detail?name=VoodooHDA.kext.2.7.2-10.6.zip&can=2&q=
Try replacing the key IOPCIClassMatch by IOPCIPrimaryMatch and set your ID in its value.
Before
IOPCI[color=#FF0000]Class[/color]Match
0x04030000&0xffff0000
After
IOPCI[color=#FF0000]Primary[/color]Match
0x[color=#FF0000]3b56[/color][color=#008000]8086[/color]
0xDeviceIDVendorID
To find your device/vendor ID
http://Olarila.com/forum/viewtopic.php?f=18&t=63
Try replacing the key IOPCIClassMatch by IOPCIPrimaryMatch and set your ID in its value .....
New day - new hope ! I worked as you told me to do yesterday, and .....
You are the best ! ;-)
I got the kext from your link to be quite sure I do not mess anything and changed OPCIPrimaryMatch and values.
for me it is :
IOPCIPrimaryMatch
0x3a3e8086
And worked !!!!
So now, in Output Tab I have :
Line-out (Green rear) -- that one I use for sound output, and
Digital-out (Black HDMI) -- never used, not sure if it works ...
The front Headphones output functions too.
Now, do you think that my X-Fi Titanium Family Soundblaster card will do it ? And is it possible to have two cards in VoodooHDA ? Two strings into the same IOPCIPrimaryMatch, or another Key ? Or not possible at all.
In any way, now I'm happy ;-)
Thank you very much !
Popeto :ugeek:
I think it doesn't work with 2 cards, that's why we specify the card ID in IOPCIPrimaryMatch instead of a range in IOPCIClassMatch (not sure, you can test).
I will try. Basically the question is if it will work with the other card, if I put his numbers, even w/o the m/b one (I think I have to disable it first from BIOS, right?).
Because of the fact I don't use AppleHDA, do you think I need the patched DSDT, or I'll get sound with VoodooHDA w/o DSDT (I don't know what exactly did change in it ...)
Popeto :ugeek:
remove kexts
add in boot.plist
<key>GeneratePStates</key>
<string>Yes</string>
<key>GenerateCStates</key>
Thanks Mald0n for your help, with your help and the support of oldnapalm, we did it !
Thank you !
Popeto :ugeek:
If the offboard card works with VoodooHDA, you don't need to disable the onboard one, just replace 0x3a3e8086 by device/vendor ID of the other card.
You can keep using the DSDT patched by Maldon, you don't need the HDEF patch I applied.
See trick 4 on official topic about 2 sound cards
http://www.projectosx.com/forum/index.php?showtopic=355
4. If you have two sound cards, for example other one is HDMI output on Video card then made info.plist
IOKitPersonalities
SoundCard
CFBundleIdentifier
org.voodoo.driver.VoodooHDA
IOClass
VoodooHDADevice
IOMatchCategory
VoodooHDADevice
[color=#ff0000][b]			IOPCIPrimaryMatch
0x284b8086   -- place here deviceID of your sound card (Chipset HDA device, not a codecID!)
[/b][/color]IOProviderClass
IOPCIDevice
IOUserClientClass
VoodooHDAUserClient
NodesToPatch
VoodooHDAVerboseLevel
1
HDMI
CFBundleIdentifier
IOClass
VoodooHDADevice
IOMatchCategory
VoodooHDADevice
0x033f1002   -- place here deviceID of your HDMI device on video card
IOPCIDevice
IOUserClientClass
VoodooHDAUserClient
NodesToPatch
1
