Aorus Pro WiFi z390 + Gigabyte Alpine Ridge + Gigabyte Titan Ridge + Vega 64
Hi, looking for some help to get a working DSDT in the hope it may help with my Thunderbolt USB issue - My LG 5k Display used to work fine using Catalina but since moving to Monterey I no longer get access to the integrated webcam or speakers.
I run the hackintosh using the Vega 64 to run 3 displays (two of which are Thunderbolt and passed through the Alpine and Titan Ridge thunderbolt cards) with the integrated Intel graphics only used in headless mode for acceleration.
I have a separate USB mapping to keep things under the 15 port limit.
Thanks for any help you can give on getting me a proper DSDT  sorted!
Send me -iMac.zip
remove ssdt olarila
check ur PM
