wolferine Posted December 22, 2021 Posted December 22, 2021 (edited) Hi, folks! I was able to install macOS Monterey with the olarila EFI for Alder Lake, and is pretty amazing that it works at all cores. Sound works with alcid=1, and wifi works with native broadcom CENVI card, also realtek lan with lucyRTL8125, and the other lan port (has 2) is a intel i-219V and works right with intelmausi.kext. The issues i am having is about sleep, it goes to sleep, but in a few seconds it wakes up. Normal, if is not optimized for this board and processor. Also no right names on PCI devices, and XHCI names on USB. The Port Hs13 is about LED control, cos the motherboard has a color led inside and is pretty cool, but when I change to macOs, the light freeze on one color. Another issue is when I restart or switch off, at the beginning of post, it forces to safe mode, and the clock of the MB restarts, I was checking fixing RTC, and nothing to do with that, may is more about some config in NVRAM. I was imposible to turn the system to macpro 7,1, just with imacpro 1,1 works. The name of the processor is not right too. And also I have made the DSDT dump in windows (results.zip) , just in case, and the Sendme file too! I would like to learn about the process, as much as I can, but need help to tune it right! Results.zip Send me macBOSSs-iMac-Pro.zip Edited December 22, 2021 by wolferine more info
Administrators MaLd0n Posted December 22, 2021 Administrators Posted December 22, 2021 save one ioreg with this efi folder https://www.transfernow.net/dl/20211222OPKdn6mA -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
Administrators MaLd0n Posted December 22, 2021 Administrators Posted December 22, 2021 use this efi folder https://www.transfernow.net/dl/20211222j1wPRHai check ur PM. add me in whatsapp or telegram for remap usb, etc -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
wolferine Posted December 22, 2021 Author Posted December 22, 2021 (edited) A new Send and IOreg https://www.transfernow.net/dl/20211227O0x5t88B And the EFI: https://www.transfernow.net/dl/20211227E3R73dEM Edited December 27, 2021 by wolferine
