Good day guys. How  U doing?
Well. I'm trying A Vanilla Opencore in my Laptop and was able to install the system. But I can boot only using another flashdrive with Clover.
I already set up the EFI with the files needed and it just reboots after choosing macOS in OC picker.
Used ocvalidate and it reports the config.plist is fine.
I'll leave the EFI folder with the last boot report after the specs.
Laptop Specs:
Alienware M'11xR3
CPU: Core i5-2537M 1.4Ghz
RAM: 8GB DDR3/1333 (2x4)
iGPU: Intel HD Graphics 3000
dGPU: Nvidia GF GT540M (Disabled in BIOS)
Storage: Kingston SSD 480GB
EFI Folder: https://www57.zippyshare.com/v/LnVhScvE/file.html
Regards.
need check on OC manual things for legacy boot
