Issue with unsigned AMDRadeonX3000
Hi, 2 days ago I managed to install Mac os Mojave on my laptop from Alienware,
I had recently installed High Sierra and everything was
going very well including Wi-Fi and Video Qe-Ci, but in Mojave
I have a problem with video acceleration more precisely AMDRadeonX3000.kext
which cannot load it because it has a problem with the certificate,
the other related kexts do not have this problem, I have attached some
screenshots to see, please help me, Mojave works faster, it loads with
the same EFI from High Sierra, Sleep and Wake is a bit faster than
its predecessor, the video card is recognized correctly as in High Sierra,
the AMDRadeonX3000 file is the latest build that they took out
of Monterey and downloaded .pkg from Github. What can I do to get the s.o.
to load it in kextcache, thanks in advance.
here is the files for non metal card terascale :https://github.com/dortania/PatcherSupportPkg
Edited by ovidoi
  1. MAC PRO 7.1 - CPU - Inel Xeon E5-1620 v1 3,6 Mhz Turbo-4.4 Mhz, MB - Lenovo S30 MB Socrates V1, RAM - 32GB DDR3 ECC dual channel, VIDEO - AsRock Radeon RX550 Phantom 2GB, SSD ADATA SU 650 250 GB WINDOWS 1124H2 , SSD ADATA SU650 128GB Sequoia 15.2.
  2. Macbook pro 3.1 2007 Core 2 Duo, Ram 2GB, El Capitan. SSD Kingstone 128 GB.
  3. Alienware M17x R3 - MacBook Pro 16.4 CPU i7-2670QM 2.2 Ghz, turbo 3,2 Ghz, Ati Radeon HD 6850M 1024GB, 10 GB DDR3, ssd ADATA 650 240GB, Catalina 10.15.7 , ssd ADATA SU650 240GB Sequoia 15.2, SSD ADATA SU 650 250 GB WINDOWS 11 24H2  Sata 6Gb.
many gpu lose support after high sierra
stay in high sierra
Hi, but how to add new certificate to this kext, i try to patch from opencore patcher, this app download and reinstall kest's but only issue with invalid certificate and cannot add to kernel cache, s.i.p. is full disable, all kext's are loaded except this AMDRadeonX3000. Thx.
Sorry more exactly, what pls. not understand very good english.
No fix, Admin, close topic pls.
Guest
This topic is now closed to further replies.
