This is my first attempt to build my own project. Almost everything is going easy and well, but even with weeks of research I can't get any close to make HDMI audio works. It's soo disappointing.
I tried many things. Briefly:
* I did a fresh ML install and uptdate to 10.8.3;
* Added device id (0x68BE1002) at IOPCIMatch on ATI5000Controller.kext and AMDRadeonAccelerator.kext;
* Made these changes in org.chameleon.Boot.plist:
GraphicsEnabler
Yes
AtiConfig
Vervet
EnableHDMIAudio
Yes
* I also tried copy 1002_68b9.rom to /Extra and enable UseAtiROM on Boot.plist, but I'm got some Kernel Panic. After that, I read that this technique is obsolete, so I gave it up of this.
* For sound I tried the VoodooHDA v2.7.3 from multishit, with Info.plist edited to add a new IOKitPersonalities for HDMI output. This resulted in perfect sound in green output and silence in HDMI. Reading more I discovered that this method is obsolete since VoodooHDA v2.8.0
* Than I use VoodooHDA v2.8.2, that give me the same result all good in green line and nothing in HDMI.
My config is:
Intel Core i5-750 2.66GHz
12GB Ram, 1TB HDD
XFX Radeon HD 5750 1GB DDR5 PCIE
Assus P7P55D LE
Audio VIA VT1828S
Any Thoughts? Any help?
