About EFI folder for i3-10105f, RX550 4GB, 16GB RAM and AsRock B460M Pro
Hi Maldon,
I have i3-10105f, RX550 4GB, AsRock B460 Pro motherboard and 16GB of RAM. May I ask you if you can share the Open Core EFI folder for me and also may you edit it for me because you told me my GPU is not fully compatible and some necessary changes need to be made but I do not understand how? Thank you a lot in advance!
Use comet laker efi desktop folder, reboot and extract one sendme
https://www.olarila.com/topic/5676-hackintosh-efi-folders-for-all-chipsets-clover-and-opencore/
yes
