Hi Guys, Thanks for reading, excuse me for my bad englisch.
This are my specs:
4GB ram, 500 GB Hitachi HDD
Asus x75A Mainboard with i3-2310m
Intel HD3000 sandy bridge, (0x1116) 1600 x 900
Intel HM70 Chipset Express
Mountain Lion 10.8.2
Here is what id did until now.
i got smbios 8,1
Create DSDT, patch with the patches (In my case i used Duallink, DTPG)
My System Info now says INTEL HD Graphics 3000 Mobile 385 MB, and i have qe ( i can turn on transparent menu bar), but no vga or hdmi output works, can please someone take a look at my dsdt and patch the hdmi/vga? i prefer hdmi
dsdt it in the attachment
maybe kernel cache ?
must be rebuild ?
after u boot and all good
go in terminal
sudo kextcache -prelinked-kernel
must be rebuild ?
go in terminal
some times it does work sometimes only with -f, can this be cause i use mbr parition?
This are my specs:
Intel HD3000, (0x1116) 1600 x 900
Intel HM67/HM70 Chipset Express
1. Using unishit USB with pached osxinstall.mpkg for MBR. (I need MBR cause my BIOS doesn't read GUID from booting).
2. Boot from mountain lion usb with commando "-v -f" and go trough the installation.
a. Create a partition, with MBR as table and Journaled as format.
3. Booting into OS X for the first time with -f -v (welcome screen), grazy colours again, but i went trough the setup anyway
4. Copy my Extra folder with org.chameleon.boot.plist, smbios 8,1 and earlier patched DSDT (with TPGT and duallink patched) to /Extra. (dsdt has 8 warning left, i cant fix them myself).
4. Copied multishit to desktop and installed with:
Patched AppleIntelCpuPowermanagement,
fakesmc + fakesmc plugins
ps/2 keyboard mouse and trackpad
Chimera Bootloader
5. Run kext utility to repair caches and permissions, rebooted after that step.
5. Fix the 4k sector to be able to boot from hdd
a. open terminal in os x setup (from usb)
b. dd if=/Volumes/"unishit Volume Name"/usr/standalone/i386/boot1h of=/dev/disk0s1
8. Reboot (-v)
I can now fully boot from hdd without unishit usb.
My System Info now says INTEL HD Graphics 3000 Mobile 385 MB, and i have qe, without having to use any bootflag, but no vga or hdmi output.
wifi, lan, keyboard and trackpad works aswell.
This are the two thing i wanne focus on now:
- Sometime the notebook just turns off suddently;
- No HDMI and/or VGA (prefer HDMI);
Can someone please help me further?
