u can use same files with new processor
The DSDT causes kernel panics, I cannot boot with it, have to disable it to boot into Mac.
Gigabyte Z490 Vision D
i7-11700K RocketLake
Powercolour RX6800XT
MacOS Big Sur
Monterey
I generally do not use wifi much but when I try in Monterey, it does not work but works perfectly in Big Sur. Also in Monterey, the bluetooth will not connect to any of my iPhones or Macs but will connect to android. In Big Sur bluetooth connects to everything properly.
The attached error is when I try to turn wifi on.
Screen Shot 2021-11-29 at 8.12.59 PM.zip
MacOS Big Sur
Monterey
