Hello.
Really hard dude, I've got it , though.
If u could give me a hand about the USB ports I'd really appreciated. It's the only thing left for a 100%vanilla hack.
Thanksa lot
I found that
Ruben$ sudo kextcache -prelinked-kernel
Password:
Can't record kext in identifier lookup dictionary; no identifier.
Kernel file /mach_kernel does not contain requested arch: i386
BJUSBLoad.kext - no dependency found for com.apple.kernel.libkern.
BJUSBLoad.kext is missing dependencies (including anyway; dependencies may be available from elsewhere)
something is wrong with u system kext...
that's why u boot problems...
the other msg no problem
u kernel cache have problems...
Hello I can't see anything
PMAP: PCID enabled
Darwin Kernel Version 12.2.0: Sat Aug 25 00:48:52 PDT 2012; root:xnu-2050.18.24~1/RELEASE_X86_64
vm_page_bootstrap: 1894816 free pages and 54880 wired pages
kext submap [0xffffff7f80741000 - 0xffffff8000000000], kernel text [0xffffff8000200000 - 0xffffff8000741000]
zone leak detection enabled
standard timeslicing quantum is 10000 us
standard background quantum is 2500 us
mig_table_max_displ = 74
TSC Deadline Timer supported and enabled
Refusing new kext com.apple.driver.AppleRTC, v1.5: already have prelinked v1111.0.
corecrypto kext started!
Running kernel space in FIPS MODE
Plist hmac value is 735d392b68241ef173d81097b1c8ce9ba283521626d1c973ac376838c466757d
Computed hmac value is 735d392b68241ef173d81097b1c8ce9ba283521626d1c973ac376838c466757d
corecrypto.kext FIPS integrity POST test passed!
corecrypto.kext FIPS AES CBC POST test passed!
corecrypto.kext FIPS TDES CBC POST test passed!
corecrypto.kext FIPS AES ECB AESNI POST test passed!
corecrypto.kext FIPS AES XTS AESNI POST test passed!
corecrypto.kext FIPS SHA POST test passed!
corecrypto.kext FIPS HMAC POST test passed!
corecrypto.kext FIPS ECDSA POST test passed!
corecrypto.kext FIPS DRBG POST test passed!
corecrypto.kext FIPS POST passed!
AppleACPICPU: ProcessorId=1 LocalApicId=0 Enabled
AppleACPICPU: ProcessorId=2 LocalApicId=2 Enabled
AppleACPICPU: ProcessorId=3 LocalApicId=1 Enabled
AppleACPICPU: ProcessorId=4 LocalApicId=3 Enabled
AppleACPICPU: ProcessorId=5 LocalApicId=4 Disabled
AppleACPICPU: ProcessorId=6 LocalApicId=5 Disabled
AppleACPICPU: ProcessorId=7 LocalApicId=6 Disabled
AppleACPICPU: ProcessorId=8 LocalApicId=7 Disabled
AppleACPICPU: ProcessorId=9 LocalApicId=8 Disabled
AppleACPICPU: ProcessorId=10 LocalApicId=9 Disabled
AppleACPICPU: ProcessorId=11 LocalApicId=10 Disabled
AppleACPICPU: ProcessorId=12 LocalApicId=11 Disabled
AppleACPICPU: ProcessorId=13 LocalApicId=12 Disabled
AppleACPICPU: ProcessorId=14 LocalApicId=13 Disabled
AppleACPICPU: ProcessorId=15 LocalApicId=14 Disabled
AppleACPICPU: ProcessorId=16 LocalApicId=15 Disabled
calling mpo_policy_init for TMSafetyNet
Security policy loaded: Safety net for Time Machine (TMSafetyNet)
calling mpo_policy_init for Sandbox
Security policy loaded: Seatbelt sandbox policy (Sandbox)
calling mpo_policy_init for Quarantine
Security policy loaded: Quarantine policy (Quarantine)
Copyright © 1982, 1986, 1989, 1991, 1993
The Regents of the University of California. All rights reserved.
MAC Framework successfully initialized
using 16384 buffer headers and 10240 cluster IO buffer headers
IOAPIC: Version 0x20 Vectors 64:87
ACPI: System State [s0 S3 S4 S5] (S3)
RTC: Only single RAM bank (128 bytes)
AppleIntelCPUPowerManagement: Turbo Ratios 0046
AppleIntelCPUPowerManagement: (built 23:03:24 Jun 24 2012) initialization complete
AppleACPIBatteryManager Loading...
AppleACPIBatteryDevice loading...
PFM64 (36 cpu) 0xf80000000, 0x80000000
[ PCI configuration begin ]
mbinit: done [64 MB total pool size, (42/21) split]
Pthread support ABORTS when sync kernel primitives misused
console relocated to 0xf80000000
PCI configuration changed (bridge=5 device=1 cardbus=0)
[ PCI configuration end, bridges 4 devices 11 ]
rooting via boot-uuid from /chosen: 3F08E8F3-FA17-3736-A75C-EA81D58DAA64
Waiting on IOProviderClassIOResourcesIOResourceMatchboot-uuid-media
com.apple.AppleFSCompressionTypeZlib kmod start
com.apple.AppleFSCompressionTypeDataless kmod start
com.apple.AppleFSCompressionTypeZlib load succeeded
com.apple.AppleFSCompressionTypeDataless load succeeded
AppleIntelCPUPowerManagementClient: ready
Got boot device = IOService:/AppleACPIPlatformExpert/PCI0@0/AppleACPIPCI/IDE0@1F,2/AppleIntelPchSeriesAHCI/CHN0@0/IOAHCIDevice@0/AppleAHCIDiskDriver/IOAHCIBlockStorageDevice/IOBlockStorageDriver/WDC WD3200BPVT-80ZEST0 Media/IOGUIDPartitionScheme/Hard Drive@2
BSD root: disk0s2, major 1, minor 3
Kernel is LP64
ath_get_caps[4038] rx chainmask mismatch actual 1 sc_chainmak 0
0.718043: ath_get_caps[4013] tx chainmask mismatch actual 1 sc_chainmak 0
0.722498: Atheros: mac 192.2 phy 14.0 radio 12.0
0.722510: Use hw queue 0 for WME_AC_BE traffic
0.722518: Use hw queue 1 for WME_AC_BK traffic
0.722525: Use hw queue 2 for WME_AC_VI traffic
0.722532: Use hw queue 3 for WME_AC_VO traffic
0.722540: Use hw queue 8 for CAB traffic
0.722546: Use hw queue 9 for beacons
0.722692: wlan_vap_create : enter. devhandle=0xc487e658, opmode=IEEE80211_M_STA, flags=0x1
0.722749: wlan_vap_create : exit. devhandle=0xc487e658, opmode=IEEE80211_M_STA, flags=0x1.
0.722844: start[1012] sc->sc_inuse_cnt is at offset: 203c, sizeof(_sc->sc_ic) is 25f0
Waiting for DSMOS...
macx_swapon SUCCESS
AirPort_AtherosNewma40: Ethernet address e0:b9:a5:ae:40:fd
IO80211Controller::dataLinkLayerAttachComplete(): adding AppleEFINVRAM notification
IO80211Interface::efiNVRAMPublished():
23.081407: ATHR: unknown locale: 60
AtherosNewma40P2PInterface::init name role 1 this 0xffffff8011a9e000
AtherosNewma40P2PInterface::init() role 1
AirPort: Link Down on en0. Reason 1 (Unspecified).
en0::IO80211Interface::postMessage bssid changed
23.721866: ATHR: unknown locale: 60
Welcome to ControllerMate v4.6 (64-bit)
ElanTech Touchpad driver v1.7.0 by EMlyDinEsHMG © 2012
Elan: Detecting the touchpad
Previous Shutdown Cause: 3
DSMOS has arrived
Elan: Touchpad found, Assuming hardware version 3 (with firmware version 0x450f01)
No interval found for . Using 8000000
Sound assertion in AppleHDAController at line 1294
Elan: Placing the Touchpad into Absolute mode
Elan: Successfully placed touchpad into Absolute mode
Transcript Offline - Buffer Pool Allocate [181000] failed
Elan: MouseInformation { 0x20, 0x03, 0x64 }
Elan: Enabling the touchpad
24.424778: setWOW_PARAMETERS:wowevents = 2(1)
33.557112: setDISASSOC from ATH_INTERFACE_CLASS disconnectVap
33.557142: switchVap from 1 to 1
33.572426: performCountryCodeOperation: Not connected, scan in progress[0]
33.578619: ATHR: unknown locale: 60
33.594316: ATHR: unknown locale: 60
33.594989: ATHR: unknown locale: 60
en0: 802.11d country code set to 'GB '.
33.712248: ATHR: unknown locale: 60
en0: Supported channels 1 2 3 4 5 6 7 8 9 10 11 12 13
en0: BSSID changed to 84:c9:b2:ba:23:98
AirPort: Link Up on en0
34.424144: apple80211Request[10292] Unsupported ioctl 111
AirPort: RSN handshake complete on en0
42.779028: ATHR: unknown locale: 60
43.399173: ATHR: unknown locale: 60
43.415192: ATHR: unknown locale: 60
nspace-handler-set-snapshot-time: 1362153214
NoEjectDelay --Info-- init 4.1.0-10.8
NoEjectDelay --Info-- start
NoEjectDelay --Info-- device: Keyboard (ApplePS2Keyboard)
47.084276: ATHR: unknown locale: 60
52.302734: ATHR: unknown locale: 60
NoEjectDelay --Info-- device: ControllerMate (Virtual Keyboard)
NoEjectDelay --Info-- device: ControllerMate (Virtual Consumer)
EAPD: Sending Command
EAPD: Enabled Successfully
considerRebuildOfPrelinkedKernel org.pqrs.driver.NoEjectDelay triggered rebuild
Sandbox: sandboxd(263) deny mach-lookup com.apple.coresymbolicationd
Rubens-MacBook-Pro:~ Ruben$
that is the problem
that is the problem
I dont think thats the root of my non-working Usb ports' issue.
My Usb ports didnt work before I set volume and eject controls through virtual-mate
what u want i see in this pictures ?
is better u tell me what u see in it...
meanwhile try this one
litle mod in usb names
