Monterey on Asus ROG GL552VW = WiFi and bluetooth not working
Hello,
I have installed macOS Monterey on my Asus ROG GL552VW with "EFI Clover Notebook 100.200" folder.
The Wifi and Bluetooth card is a Broadcom BCM94352Z.
The Wifi & Bluetooth was working with Big Sur but it is not working with Monterey.
I have tried several kexts but none of them worked.
Help to make it work would be appriciated :)
Edited by mapomme1108
this wifi card need device id 43a0 with AirportBrcmFixup.kext
BT need BlueToolFixup.kext, BrcmFirmwareData.kext and BrcmPatchRAM3.kext
Hello,
Thank you for your help.
I have added BlueToolFixup.kext, BrcmFirmwareData.kext and BrcmPatchRAM3.kext and bluetooth works. Thanks!
But I don't know how to add device id 43a0 for AirportBrcmFixup.kext : is it in config.plist?
via device properties, ssdt or direct on dsdt
entries in config.plist is added?
There is no entry for voodoops2 in config.plist and I don't know what code I have to add. Can I do it with Clover Configurator?
u need add all entries
