please, I need help!! my screen is messed up
Hello please, I need help,
I tried, but I can not get my laptop to work with higher resolution than 1024x786, my graphics card is an HD 3000, 116. my laptop is a samsung nt9000xa 58b.
I explain my problem,
I tried with all kext that are in kext.com kext (osx86.com), I modified the plist and add the 0x01168086, when I do this my screen breaks, (the screen is blank and lines as static)but I can see at the bottom of the screen image.
leave a picture that best explains my problem.
Thanks in advance.
with Print Screen
As I see it
I leave my files
send_me.zip
sorry for the late reply,
i been trying all day and nothing happened when i patch the dsdt.
If I delete all intel kext only have resolution 1024,
if i try the intel kext, the screen worsened, and I cant see anything, except white screen messedup.
sorry for the bad english.
here is my dsdt patchet (rename .zip to aml)
PD. multishit will not let me install, I have to install it with dsdtse
and,,thank you very much for taking the time to help people with their Hackintosh
dsdt.zip
are you using the right smbios?
hi! mendietinha
I generate one with chameleon wizard, this are the files i use.
the smbios is right, but you use some flags that you actually dont need. like if you use a ssdt, you dont need:
GenerateCStates
Yes
GeneratePStates
Yes
thaks, I was not sure about that, so i put him, but i will take away.
and,, you will have some more ideas of what to do for my screen?, whatever I try,
I already run out of ideas.
thanks in advance.
Hello, my friend!
If your notebook is like mine, Samsung Series 9, what I believe the problem is, is that my notebook uses an Intel HM75 south bridge with which Mac expects to find an Ivy Bridge processor with a HD 4000 graphics, and it only finds a Sandy Bridge processor with HD 3000 graphics. I don't know if there's a way of changing some kexts to workaround the problem.
Don't know why Samsung decided to use what appears to be an Ivy bridge southbridge with a sandy bridge processor, whether it's intentional to prevent hackintosh on their products (even more if you think of the Intel Centrino Advanced-N 6235 Wi-Fi card that doesn't have -- and I think never will -- a driver ported to Mac) or they just wanted to spend less on the components.
I don't have the solution, just to help clarify what the problem might be. I ended up using Ubuntu and learned to live without Mac OS X for now.
