Tsurugi Posted July 29, 2011 Share Posted July 29, 2011 hi hi have installe thanks to Kynnder VoodooHDA 2.7.2 audio driver but the sound the sound does not come out well has the background noise .... and sometimes when I get kernel panic and reboot to start the system I use -f-v ... there is a way to get this card with the AppleHDA driver that works on snow in a clean way? Link to comment Share on other sites More sharing options...
slipttees Posted September 1, 2011 Share Posted September 1, 2011 try new kext: http://dl.dropbox.com/u/30344638/kexts/Som/VoodooHDA.2.7.3.kext.zip remove AppleHDA /S/L/E and install voodoohda /S/L/E too. rebuild mkext. done ! Dell Optiplex 790 - iMac12,1 - High Sierra 10.13.6 - Ok Intel® Core i5-2400 CPU @ 3.10GHZ - Ok Intel HD Graphics 2000 - Vesa Driver / Replace Zotac 8400GS 256MB - Clover + NvidiaInject - OK DDR3 4.0GB 1333Mhz - Ok Realtek ALC269 - AppleALC.kext - Ok Broadcom BCM43224 - AirportBrcmFixup.kext - Ok Intel 82579LM Gigabit Ethernet - IntelMausiEthernet.kext - Ok HDD Hitachi 500GB - Ok Link to comment Share on other sites More sharing options...
