use in 32
no problem
ahahah rigt is good
It's not important, it doesn't work the same way as in Windows.
OS X is a 32/64-bit hybrid. Just like on a real Mac, as long as your CPU has the EM64T instruction set, you can run 64-bit apps and access up to 32GB RAM even if you're running in 32-bit kernel and drivers mode.
yes ok no prob another question with audio ... open new thread thanks
